Nokia Health products (Body+ connected scales etc)
I found the download menu and things work now - from the HA side. But the authorization procedure after the integration comes up with an error saying that there is a mismatch between the redirect URL and the callback URL. When I created the developer account I gave my own URL (website) but when HA sends me to the authorization website it uses the local IP of the HA installation. And of course there is a mismatch.
What do you do?
I reckon that It will also be a problem when the Withings component becomes a part of HA.
I had the same problem at first. You need to adapt the base_url for withings to your own url:
withings:
    client_id: xxx
    client_secret: xxx
    base_url: xx
    profiles:
        - xxx
    measures:
        - bone_mass_kg
Afterwards the authorization website forwards you to [yoururl]/api/withings… (with error) there you have to change your url to the local IP of the HA in the browser address bar.
Thank you. Doing what you proposed. Got past the first error. Changed to local IP:8123 but are presented with an empty (white) screen. Tried to refresh the page and got the error ā€œthe server got itself into troubleā€
Running Hassio e.g. in a Docker
Thank you for your patience
Update.
Tried again and everything works now.
Feeling happy
Thank you for your patience and help
is it possible to get the sleep score ?
The API doesn’t have a score attribute. Rather, it appears to be the number of hours slept. In all, I think this is calculated on the app.
I have to do the authentication procedure every time I restart HA. Is that expected.
Any news of when the component gets integrated in HA?
The auth procedure is suppose to be a one time process. I ran across a similar problem today and updated the PR. That should fix the issue.
No estimation of when this will get merged although I’m feeling pretty confident about it being done (we’ll see).
Auth procedure confirmed working as a one time process.
We have to wait patiently but as long as it works as a custom component, it is much easier
Hi, thanks for this integration. I have Withings Steel HR, which tracks heart rate during sleep. But I am getting only weight, height, and deep sleep and light sleep indicators. Heart rate sensors all show 0. In sleep stats Health Mate shows HR during sleep. Can I do something so that heart rate sensors show something?
Withings provides at least two measures for collecting heart rate. One is in sleep, the other is the normal BPM. It’s probably one of of those, my guess is it will be the regular BPM as that information is collected all day too.
I had the same problem while developing the component. Turns out that HA uses translation files and will generate them at build time. For custom components, I bet the same applies. I haven’t worked with this as a 3rd party component but you could try this:
  • Create the directory custom_components/withings/translations
  • Copy the custom_components/withings/strings.json to custom_components/withings/.translations/en.json
Cannot find /.translations/
Do you mean /translations/ (without the .)
Thanks, this fixes it! :+1:
@ajmm. Can you tell me what you did? Does it matter which language HA is set to. Mine is Danish. Should the .json file be renamed?
All I did was create a .translations folder with stings.json renamed to en.json. You might try da.json if it doesn’t show up.
It worked - in English. Thank you.
Every time I restart HA I am notified that a new integration has been discovered, namely Withings. Even though it is configured already. But of course you can ignore it.
Same here every time I restart the integration is gone , I had to erased and re-integrate to make it work
@insaid. Have the same problem. Have a sleep mat. The values for heart beat and respiration show zero. Sensors are found but no values. Did you find a solution?
No, I could not figure it out. I though of waiting for the component to appear in standard HA package, maybe then will try again.
@ajmm. Did anyone succeed in authorizing the Withings component in 0.99b0?
