Non-existant /etc/systemd
I’m sure I’m just not understanding this correctly, so I hope someone could explain it.
I’m running Proxmox 8.1.3 with HAOS (2023.12.03) in a VM.
I have 1 proxmox node named “proxmox-shop” at 192.168.0.28
Under that node, I have:
  1. 100 (haos) at 2 IP addresses: 192.168.0.103 and 192.168.0.162
  2. 102 (NUT) running Debian 12 at 192.168.0.233 (DHCP)
  3. 101 (debian) at 192.168.0.236 (DHCP)
Here is my question:
I can SSL directly into the HA VM and I get this prompt:
[core-ssh etc]$
If I “cd /etc” and “ls” I don’t see the “systemd” folder.
Same result if I use the HA add-on: “Terminal & SSH”
If I use the “Console” facility of Proxmox or the , I get the prompt:
ha >
I see from another thread that if I type at this prompt:
login
It brings me to a prompt:
from there I can cd /etc/systemd
  1. How do I access /etc/systemd from an SSH session
  2. Can someone explain what these different types of logins/access-es and different prompts are?
Thank you.
