Non-USB Zigbee hub integration issue
I’ve just received a Zigbee gateway hub (link to the hub) to integrate it with Home Assistant. But the problem is whenever I try to add Zigbee Home Integration, the device is not detected automaticity like it usually happens with Zigbee dongles. I’ve tried using all radio types to connect, none works. Whatever radio type I choose, I need to enter Serial device path. Such as its non USB device, I enter IP address of the device in format socket://192.XXX.X.XXX. or tcp://192.XXX.X.XXX. Also, I’m not sure what port to use. I run my own Home Assistant on OrangePi. I figured out that the device got 6668/tcp open irc and 6682/tcp open unknown ports. So I add each port to the IP address in the serial device path field. But it always throws and error “Failed to connect”. I see that some people use zigbee2mqtt, Should I try to connect my hub via the add-on?
If anyone can help how to connect it, please drop a message. Or maybe there is a discussion on that, please give me the link
P.S. The Zigbee gateway hub is perfectly working with other apps such as smart life.
Thanks all.
I don’t see it listed as a supported ZHA module, so I doubt you can integrate it in ZHA, sorry.
PS - it’s not on Z2MQTT supported list either.
