I have an ESP32 NODEmcu that is connected to a MOSFET irlb8721. This all works fine, the problem i’m having is when dimming at at low values (1-5%) is dose not transition smoothly. To exaggerate the problem I put the default_transition_length: 5s
during dose 5 seconds it jumps 3 times when it goes from 1-5%. Changing the gamma_correct
to a smaller number makes it harder to spot, changing it to a higher number makes it even more obvious.
My guess is that this has something to do with the way ESPhome generates the transition curve (which i understand is done with (this)
static float [smoothed_progress]()(float x) { return x * x * x * (x * (x * 6.0f - 15.0f) + 10.0f); }
and how the gamma_correct is applied.
I would say i understand the high level of why these 2 functions are there but if anyone can point me in the right direction i would be happy to sit and test different numbers to se what works.
My ESPHome config:
light:
- platform: monochromatic
output: G32
default_transition_length: 1s
gamma_correct: 2.8
output:
- platform: ledc
pin: GPIO32
frequency: 19531 Hz
min_power: 0.5%
zero_means_zero: true
