Noob automation problem
Hi all,
It has been quite some time since I delved into the world of HA and now I don’t seem to be able to get a simple automation working.
Can someone tell me what is wrong with this automation. When I check the config it gives me an error:
- alias: Rolluik Slaapkamer openen om 7u op weekdagen.
    platform: time
    at: '7:00:00'
  condition:
    - condition: state
      entity_id: binary_sensor.workday_sensor
      state: 'on'
    - data:
      entity_id: cover.slaapkamer
      service: cover.open_cover
Remove -data from your action.
Thanks! that seems to solve it. Any chance you can explain why the ‘-data’ doesn’t cause problems in this automation?
- alias: Rolluik Slaapkamer aflaten half uur na zonsondergang.
    - event: sunset
      offset: 00:30:00
      platform: sun
    - data:
      service: cover.close_cover
Neither require the - data: entry.
The first isn’t properly indented, items under data need to be indented by two spaces. Due to this it gave an error.
In your second example you are passing the data “entity_id: cover.slaapkamer” to the service cover.close_cover. In the first HA doesn’t see any data passed.
Thanks. I understand now.
Just to add to what @silvrr said, all data for service belongs under data (or data_template.) However, the service handler allows entity_id to be at the same level as service as a shortcut/convenience. So:
service: abc
entity_id: xyz
is equivalent to, and a shortcut for:
service: abc
  entity_id: xyz
Thanks for the clarification @pnbruckner! I suggest you guys start writing the docs :slight_smile:
