With version v0.114 the automation below was working fine but after updating to v1.115 it isn’t working anymore. It has something to do with the template and I think I have to fix it with input_datetime but I don’t know how to get the data from the sensor.kerstboom_uit_tijd in the input_datetime entity.
Is there someone who can point me in the right direction ?
I don’t know what kind of sensor ‘kerstboom_uit_tijd’ is but you can start by checking that it is comparable by also copying this to the Template Developers Tool. If it is not also hh:mm then the comparison will never work.
Some things recently changed with templates that I don’t fully understand. In general it strikes me as better to trigger on a time pattern, such as every five minutes, and have a condition that checks if the time is right. I am assuming that you are not setting your Christmas lights to be on at some time like 18:32:15.
Confirm the state of sensor.kerstboom_uit_tijd displays time in this format HH:MM like 06:45 or 21:30 which is the same format as sensor.time. If it displays time as HH:MM:SS then it will never match the time reported by sensor.time.
If it does include seconds in the time, you can fix it like this:
I don’t think that it is better than triggering on an input helper datetime, I just forgot about that new feature. I bet that will suite OP nicely! I need to update automations to use that myself.
And yes, hard-coded time, if it works, is best! One less “part.” I assumed that it doesn’t fit the use case though.
