Noob can't delete dead Z-wave devices?
Hi everyone,
I’ve got a fairly blank HASS Rpi4+SSD install with a Zooz ZST10-700, some Homeseer dimmers and 1 Zooz switch.
Long story short, I’ve purposly excluded all my Z-wave devices to try to start fresh but three devices I can’t seem to get rid of. Can someone point me to documentation that could speed up my understanding of ways to clean things up?
I installed file editor hoping I could open a file and look for the device ID’s or something but it’s becoming more and more confusing.
image|674x500
I solved my problems by removing the device physically then removing the hub and Zwave js. Then I went to Simplicity Studio in a PC, plugged the Zooz hub into USB went to network and hit “reset” which clears the hub’s assosiations.
Got a nice blank Z-wave environment. I wish I could check HASS for reminences of stale stuff that could be left over… .but I don’t know how.
You can already hard-reset the controller in Home Assistant, no need to use PC Controller.
Uninstalling the integration is a way to be sure of that. It will remove all devices and entities for the integration.
