debian@beaglebone:/home/homeassistant/conf/apps$ sudo appdaemon -c /home/homeassistant/conf
2017-11-18 13:13:46.124649 INFO AppDaemon Version 2.1.12 starting
2017-11-18 13:13:46.128486 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2017-11-18 07:13:46.592451 INFO Starting Apps
2017-11-18 07:13:46.860236 INFO Got initial state
2017-11-18 07:13:46.865738 INFO Loading Module: /home/homeassistant/conf/apps/hello.py
2017-11-18 07:13:46.872621 INFO Loading Object hello_world using class HelloWorld from module hello
2017-11-18 07:13:46.875206 WARNING ------------------------------------------------------------
2017-11-18 07:13:46.877349 WARNING Unexpected error during loading of hello_world:
2017-11-18 07:13:46.879443 WARNING ------------------------------------------------------------
2017-11-18 07:13:46.886865 WARNING Traceback (most recent call last):
File “/usr/local/lib/python3.5/dist-packages/appdaemon/appdaemon.py”, line 912, in read_app
init_object(name, class_name, module_name, conf.app_config[name])
File “/usr/local/lib/python3.5/dist-packages/appdaemon/appdaemon.py”, line 573, in init_object
app_class = getattr(module, class_name)
AttributeError: module ‘hello’ has no attribute ‘HelloWorld’
2017-11-18 07:13:46.890271 WARNING ------------------------------------------------------------
2017-11-18 07:13:46.892252 INFO App initialization complete
2017-11-18 07:13:46.895419 INFO Starting dashboard
2017-11-18 07:13:46.935368 INFO API is disabled
2017-11-18 07:13:47.005808 INFO Connected to Home Assistant 0.56.1
2017-11-18 07:13:48.002747 WARNING Scheduler clock skew detected - delta = 1.002608060836792 - resetting
2017-11-18 07:13:53.379079 INFO New dashboard connected: Main
appdaemon.yaml
AppDaemon:
logfile: STDOUT
errorfile: STDERR
threads: 10
HASS:
ha_url: http://192.168.1.12:8123
#ha_key: <some key>
HADashboard:
dash_url: http://192.168.1.12:5050
#Apps
#hello_world:
# module: hello
# class: HelloWorld
apps.yaml
hello_world:
module: hello
class: HelloWorld
hello.py
import appdaemon.appapi as appapi
# Hello World App
#Args:
class HelloWord(appapi.AppDaemon):
def initialize(self):
self.log("Hello from AppDaemon")
self.log("You are now ready to run Apps!")
Please help, I’m trying to learn
