@crzynik, Thank you for your reply. I’m a bit confused? Will the IGPU be good enouth to do the human and car detection on 8 x 1080N streams (960x1080) at 5 fps?
Also is there a way to streach the 960x1080 native stream of the dahua cameras to be 16x9? as it just looks odd being squashed but it looks normal when played back from the NVR?
I’ve been getting no end of issues with frigate directly installed in home assistant as a addon in the proxmox vm. The streams loads itermittetly at best and there are a stream of errors in the frigate logs. It does not detect any hardware acceleration. Is it looks like the only way to go is either using a priviliged lxc container which i see as a security risk or to go down the frigate VM route with a coral tpu…
