First post. I’m trying to get my head around setting up Hassio and have already learnt quite a bit, however, I’m really struggling with getting my Xiaomi Gateway recognised. I’m getting a ‘Config Validating’ message every time on the dashboard and I have tried nearly every time I boot up. I have also tried everything that has been suggested (at least from what I have searched for) for setting up the Xiaomi Gateway. I have enabled multicasting on my router, I have tried pointing to the Mac address, the IP, rebooting, etc and still nothing shows. Here are the bits from my log - I have omitted a lot of it, as a lot of the errors are repetitions:
Update for sensor.piccadilly fails
Updating london_underground sensor took longer than the scheduled update interval 0:00:30
Updating hue light took longer than the scheduled update interval 0:00:05
20:58 helpers/entity_platform.py (WARNING)
Timer got out of sync. Resetting
20:58 core.py (ERROR)
Hass.io config check API error
20:58 components/hassio/__init__.py (ERROR)
Timeout on /homeassistant/check request
20:58 components/hassio/handler.py (ERROR)
Unable to reach bridge 192.168.0.2
20:58 components/light/hue.py (ERROR)
There is nothing here that stands out as an issue in regards to the gateway but could possibly be a network issue?
This is my config:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: #########
longitude: #########
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 14
# metric for Metric, imperial for Imperial
unit_system: imperial
time_zone: Europe/London
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
api_password: #########
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url:
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather, Underground
- platform: yr
- platform: london_underground
line:
- Bakerloo
- Central
- Circle
- District
- DLR
- Hammersmith & City
- Jubilee
- London Overground
- Metropolitan
- Northern
- Piccadilly
- TfL Rail
- Victoria
- Waterloo & City
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
# Aqara
xiaomi_aqara:
discovery_retry: 10
gateways:
- host: #########
mac: #########
key: #########
It feels like I’m being really dumb and I’m hoping it’s a simple issue, but can someone take pity on a noob and offer some recommendations.
I can tell you the gateway has the latest firmware installed, the key does not change and is correct, I’m running a Pi1 model B (wired to the router) and I have the latest version of Hassio installed.
Thanks!
