Hi, i’m coming from Domoticz. I’m on hass.io image on raspberry, with beta openzwave which is working (discovered deviced previusly on the controller with domoticz). The problem is about my fibaro blind controller, wich i need to invert.
I try to add in config.yaml these lines but it’s not working. Could be that these are for the older zwave addon?
zwave:
usb_path: /dev/serial/by-id/usb-0658_0200-if00
device_config:
cover.camerina_tapparella_level_5:
invert_openclose_buttons: true
invert_percent: true
thanks since now
