Hello everyone. I am setting up HA and have some motorized curtains. I want to get the position of them but there isn’t an entity with it specifically. I learned that I can set up a sensor and use this to get the value.
This current_position will tell me where the curtain is at (0=closed 100=opened). I was able to generate this code with help
sensors:
name: "Curtain Inside 2 Position"
state_class: measurement
state: "{{ state_attr('cover.curtaininside2', 'current_position')|float}}"
unit_of_measurement: "%"
But I am getting this when I check the configuration
Looking for a kind soul to help point the way to make this work. Thank you in advance.
w00zy
August 11, 2023, 3:24am
2
sensors:
curtain_inside_2_position:
tom_l
August 11, 2023, 3:37am
3
That is not correct. The old format uses value_template: not state:, and friendly_name: not name:
You should be using the new format for new template sensors.
You should also define a default value for your float filter.
New format (configuration.yaml), preferred:
template:
- sensor:
- name: "Curtain Inside 2 Position"
state: "{{ state_attr('cover.curtaininside2', 'current_position')|float(0) }}"
Old format (sensors.yaml), not preferred:
sensors:
friendly_name: "Curtain Inside 2 Position"
value_template: "{{ state_attr('cover.curtaininside2', 'current_position')|float(0) }}"
Thanks for the help. So this is what happens when I put in that code to Studio Code Server
Then checking it shows this
Here is what I have in the config file
template
- sensor:
Not sure if I did it correctly. Thanks for the previous help but I need a little more.
tom_l
August 11, 2023, 10:59am
5
That whole thing is indented two spaces too far. template: should be hard up against the margin of your configuration.yaml file. Spacing is important in YAML.
Thanks again. I’ll change that
So here is that same code hard to the left. Does this look correct?
tom_l
August 11, 2023, 12:40pm
8
You are missing the colon : after template on the first line.
Oops. I did in my example too, sorry.
I edited my post above to correct it.
Thank you. What about the line that says missing property “device_id” do I need that after the name or before the name?
tom_l
August 11, 2023, 12:46pm
10
Has all of that not cleared up after you put the colon in?
Close but it wants a platform
tom_l
August 11, 2023, 12:52pm
12
You are putting this in your sensors.yaml file. Don’t do that. Template is an integration like Sensor. It needs to go in your configuration.yaml file:
You can set up an include in your configuration.yaml file and use a seperate file if you wish.
template: !include templates.yaml
The config (without the first line “template:”) would then go in the new templates.yaml file you create.
Got it! Again thanks. Here is my config file now
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
# Example configuration.yaml entry
# Example configuration.yaml entry for Google Mail.
notify:
- name: "Steven"
platform: smtp
server: "smtp.gmail.com"
port: 587
timeout: 15
sender: "XXXXXXXX"
encryption: starttls
username: "XXXXXX"
password: "XXXXXX"
recipient:
- "[email protected] "
sender_name: "Chico House Home Assistant"
template:
- sensor:
And we are good to go!
