Hi ESPHome Experts!
I’m trying ESPHome for the last 4 days and I’ve accomplished a lot within a few hours of investigating and programming the yaml file.
But for the last 2 days I’m stuck within a problem. Let me explain:
I need to whenever a sensor in Home Assistant change it’s value, ESPHome should run a pre determined ESPHome script for each value from the sensor.
Example:
If HA Sensor value is “AAA”, than I need to run script “script_aaa”;
If HA Sensor value is “BBB”, than I need to run script “script_bbb”.
I’ve already tried:
text_sensor:
- platform: homeassistant
entity_id: $ha_sensor1
on_value:
then:
- logger.log:
format: "DEBUG - Sensor 1 Value = %s"
args: [ x.c_str() ]
- if:
condition:
lambda: 'return x.c_str() == "aaa";'
then:
- script.execute: script_aaa
- if:
condition:
lambda: 'return x.c_str() == "bbb";'
then:
- script.execute: script_bbb
But this doesn’t work!
I can convert the logic to lambda, but I don’t know how to run a script in this mode. Is there any possibility to run a script within lambda ??
How can I get this working?
Thanks in advance!
MrFroggy
You seem to have a good handle on how things are done.
