I’ve just finished installing on a Pi 3 (64bit), configured my new Zigbee dongle:
SONOFF Zigbee 3.0 USB Dongle Plus-E
and added/configured the Mosquitto broker and Zigbee2MQTT add-ons.
Seemingly without any issue. When I then try to add my only device, it does pop up as expected, but the configuration seems to either fail, or end up in a bad state where it’s added and visible, but no data is being reported. See attached pictures and log output with errors.
I have tried using the Zigbee2MQTT add-on, and have tried switching to the Zigbee2MQTT EDGE channel, without any change in behavior. The logs show a cryptic “Route error” in the bottom, but I don’t know what that means, or where to start troubleshooting:
> Zigbee2MQTT:info 2022-11-20 13:01:37: Device '0x00124b00251d224b' is supported, identified as: SONOFF Temperature and humidity sensor (SNZB-02)
> Zigbee2MQTT:info 2022-11-20 13:01:37: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Temperature and humidity sensor","exposes":[{"access":1,"description":"Remaining battery in %","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Measured temperature value","name":"temperature","property":"temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Measured relative humidity","name":"humidity","property":"humidity","type":"numeric","unit":"%"},{"access":1,"description":"Voltage of the battery in millivolts","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"SNZB-02","options":[{"access":2,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device.","name":"temperature_precision","property":"temperature_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device.","name":"temperature_calibration","property":"temperature_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device.","name":"humidity_precision","property":"humidity_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device.","name":"humidity_calibration","property":"humidity_calibration","type":"numeric"}],"supports_ota":false,"vendor":"SONOFF"},"friendly_name":"0x00124b00251d224b","ieee_address":"0x00124b00251d224b","status":"successful","supported":true},"type":"device_interview"}'
> Zigbee2MQTT:info 2022-11-20 13:01:37: Configuring '0x00124b00251d224b'
> Zigbee2MQTT:info 2022-11-20 13:01:37: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"description":"Temperature and humidity sensor","friendly_name":"0x00124b00251d224b","model":"SNZB-02","supported":true,"vendor":"SONOFF"},"type":"pairing"}'
> Zigbee2MQTT:error 2022-11-20 13:01:40: Configure failed: Error: Bind 0x00124b00251d224b/1 msTemperatureMeasurement from '0x84b4dbfffecc16b2/1' failed (Route error)
> Zigbee2MQTT:info 2022-11-20 13:01:40: Successfully configured '0x00124b00251d224b'
Can anyone point me in the right direction? I really hope to get some useful data before I give up.
