Real noob question, but I want to monitor and control my JK BMS (a battery control device) in Home Assistant. This component is available:
I have previously used ESP32’s to monitor Xiaomi BLE plant devices and it works great, but in those instances it was necessary because I had the sensors spread out away from the RPIs blue tooth range. But in this case the Pi is inches away from my JK BMS.
I am a noob to start with and haven’t set up anything in HA in a while, but I am drawing a blank here. I have a Esp32 board laying around and can set that up, but can’t I use the PIs native Bluetooth in this case instead? I wouldn’t have to worry about getting the MQTT to work etc.
Could be that I am too much of a noob to pull this off, but could you just nudge me in the right direction. What should I try to do to read the data from the JK BMS?
I know this is an old thread but I was trying to do the same as others here. If a solution hasn’t been found yet, Try batmon. It uses the bluetooth in the BMS and can be installed as an add-on or standalone on a separate raspberry pi which is how I did it since my batteries are out of bluetooth range from my home assistant server.
