Hello community!
A new Home Assistant user trying to migrate away from Homey and take full control of my house.
I have installed Home Assistant OS on a dedicated x86 PC and all is working fine.
I have also enabled the cloud trial to explore that a bit…
Now to my question!
I have been able to install Philips Hue, IKEA Tradfri, my garage doors and some other of my key devices in my house. However since I could not find the Sensibo integration in the UI installer I found it here:
https://www.home-assistant.io/integrations/sensibo
I installed the Visual Studio Code plugin and have added below lines to my configuration.yaml (taken from the documentation on the link below):
# Sensibo
climate:
- platform: sensibo
api_key: [my key here]
I then saved the file, confirmed the configuration file is valid from Home Assistant settings and then restarted the Home Assistant system to have the config reloaded.
Now what? How do I see my custom integration? How do I configure it and get my air conditioner in to Home Assistant so that I can control it? I see no change anywhere?
Thanks in advance!
