Hey.
I tasmotized a IR blaster (dont ask me why! Long story!) and I can check TASMO_IP to use the console. It works! If I send this command Ill get an IR flash to turn on a gadget.
IRsend:{"Protocol":"NEC","Bits":32,"Data":"0x807F50AF","DataLSB":"0x1FE0AF5","Repeat":0}
My MQTT settings are
user: mqtt_user
password: xxxxxx
topic: tasmotair
Full topic: tasmo/%topic%/
The Tasmota Info page (http://TASMO_IP/in?)
Program Version | 13.2.0(ir) |
|Build Date & Time|2023-10-19T09:02:08|
|Core/SDK Version|2_7_4_9/2.2.2-dev(38a443e)|
|Uptime|0T00:21:17|
|Flash Write Count|23 at 0xF5000|
|Boot Count|14|
|Restart Reason|Software/System restart|
|AP1 Information|SSId WIFI
RSSI 100%, -36 dBm
Mode 11n
Channel 6
BSSId
|Hostname|tasmotair-1234|
|MAC Address|aa:aa:aa:aa:aa:aa|
|IP Address (WiFi)|TASMO_IP
|Gateway|xxxxxxxx|
|Subnet Mask|255.255.255.0|
|DNS Server1|xxxxxxxx|
|DNS Server2|0.0.0.0|
|HTTP API|Enabled|
|MQTT Host|MQTT_BROKER_IP|
|MQTT Port|1883|
|MQTT User|mqtt_user|
|MQTT Client|DVES_F60BA6|
|MQTT Topic|tasmotair|
|MQTT Group Topic 1|cmnd/tasmotas/|
|MQTT Full Topic|cmnd/tasmotair/|
|MQTT Fallback Topic|cmnd/DVES_F60BA6_fb/|
|MQTT No Retain|Disabled|
And for a first test I went to https://HASS:8123/config/mqtt
and tried every combination of my topic name and the full name… What do I have to write into “topic” to send the command to my Tasmota device.
I also tried to correct every " and turned them into "
And as I am here helpless let me add 2 more questions
How do I create a pushbutton on my dashboard which sends the command to the Tasmota device?
And how can I use this in an automation?
When I give voicecommand X
- turn on x
- turn off y
- send command xyz via MQTT to “TASMO_IP”
Much appreciation for your help.
Help me keep my sanity
