Nordlux Smart light products
Hi
Have anyone tryed to intergrate this product. https://www.nordlux.com/products/smart-lighting/explore-nordlux-smart
Can’t find any that have.
just got myself a Brigde and all there bulbs.
And are now ready to investigating the hardware. But if annyone already have had success. Im all ears.
Sofare Ihe product is a Wifi to BT mesh brigde, bulbs are BT ofcouse. So next step is to tab the communication.
The Brigde presents itself on the network as a Sichuan AI-Link Technology Co., Ltd. product
The inside of the bridge is a Sichuan AI-Link Technology Co., Ltd. product sold of as a nordlux.
No port seams to be open
Did you get it to work with Home Assistant?
Sort off… Used the googlehome in the Nordlux. And hereby added it to the HA. BUT not what I was looking for. Im stille working on making a proper integration. Nordlux was no help. They claimed up. So Im on my own… My attack is fokus on the com between bulb and tha Sichuan AI.Link AP. Witch is labeled Nordlux. I have been looking at the code. But haven’t made a propper solution yet.
The solution is install TUYA app on your phone and parre your Nordlux dev. to it.
Use intragration in HA called TUYA using the account from your phone.
Then your good to go. (came to me when I saw BLE comm. is the same on NORDLUX and TUYA) So they are the same just different sticker !
Were you able to connect the Gateway to TUYA? It shows up for me, but no matter which device I choose it’ll error out. I assume the lights will work in the TUYA app, but then would an alternate gateway be required? I’ve messaged Nordlux regarding their integration options, hopefully they can provide atleast something
EDIT: My lights DO connect to the Tuya app, but I get zero control over the lights within the app, nor do they show up in the integration, though I may have been impatient. Assume I’m doing something wrong.
I experience exactly the same as @sondre.gronas. Did you ever get past this issue?
@Soren_Hansen, how is your HA able to communicate with the lightbulbs through BLE? Did you manage to connect the bridge to Tuya?
I did not get past the issue, I did however get a positive response from a Nordlux employee. They told me they expect to move the app over to fit the Matter protocol mid 2022 (hopefully) - and hopefully existing fixtures will be supported retroactively.
I also inquired if we would ever just be given access to operate the hub locally via an API, just like how you can communicate with the Philips Hue hub - but it doesn’t seem like they intend to give access.
Thanks, the first part sounds promising. Their own app is simply terrible, especially the Google Home integration.
Hi. How do you connect the Nordlux system to Tuya?
Hi Søren,
I have been trying to add the bridge to Tuya but without any luck.
It is automatically discovered as “Sig Mesh” but fails on connecting
I tried manually to select the various BLE gateways but still did not succeed.
The connection fails with the error message “fail to add” with no further details.
While connecting it to the Nordlux app “Nordlux smart” has no issues.
Though I get notified that there is a firmware update from version 2 to version 6, but it fails on updating
So what firmware version ae you running in your br6dge and how did you connect to Tuya. Which device type etc.
Please advise
Hello.
I’m trying to add some Nordlux products to my HA setup.
I have a couple of the bridges but only planning on setting the newest of them up, a few remote controls to the lights and some bulbs.
My question here is how did you establish the connection between Nordlux and TUYA?
I can connect all my stuff in the Nordlux app but the TUYA app times out and can’t find anything ells on the internet about this than this tread.
And can’t find the Nordlux dev thing.
I hope you can help me out here.
Hello, same for me here. When trying to add E27 Smart Bulb in Tuya app, it is discovered as SIG Mesh. but then I get a connection timeout. Even choosing the light and led bulb category does not help. It seems that the pairing process is starting because I see the bulb flashing, but then timeout. I have updated the bulb’s firmware with the Nordlux App, but now I am not able to connect to the bulb with the nordlux app :slight_smile: Hopefully I got this bulb for 5 euros :wink:
Any news on this? They just launched a new app, and new firmware for their bulbs.
Have you found a solution? I am not able to connect it even to the Tuya app.
I would also be interested in a solution!
Hi I would also be interested in finding a solution. Now I’m just using a service call to Google assistant to turn on and off light for automation. I would also like to get another solution, Tuya won’t find it. Latest firmware and I’m using the smart hub for now.
Any luck with nordlux? I’m stuck here a little bit
I just bought 3 new gu10 and they don’t even show up in my tuya app.
The old ones shows up but I can’t control them by tuya. only when I connect them to the nordlux gateway.
It would be nice if we could connect to the gateway from HA.
Today I talked with Nordlux technical support about this, and he said that they were working on supporting Matter, for local control by other devices.
What he said:
  • The original plan was to release it this year, 2025, but they have some issues getting everything working. He couldn’t give a release date.
  • Support for full local access through Matter. Other devices, like Home Assistant, can control the lights, without internet access.
  • He had already 8 light devices working with his Google Hub.
  • It’s a new Bridge. So not the Dual WiFi Bridge.
I forgot to ask if the next lights will support Matter them self, instead of being Bluetooth mesh only.
