I installed nordpool. Works fine. I want to create an automation that triggers on a certain price per kWh, or below. I cannot get it to work with the sensor and attributes that nordpool creates, because you cannot go " above or below" a state. This is what I came up with for now:
alias: VV Hal, goedkoopste tijd
description: ""
triggers:
- trigger: template
value_template: "{{ states('sensor.nordpool_cheapest_time') == now().strftime(\"%H:%M\") }}"
conditions:
- condition: state
entity_id: sensor.nordpool_kwh_nl_eur_3_10_021
state: "0.02"
- condition: numeric_state
entity_id: sensor.panasonic_heat_pump_main_outside_temp
below: 15
actions:
- device_id: 10d41516145f08ca7120ae2c88deee1a
domain: climate
entity_id: 4272c153f83ddebeeb2be1392ae76258
type: set_hvac_mode
hvac_mode: heat
domain: climate
type: set_hvac_mode
hvac_mode: "off"
Don’t mind the cheapest time part.
I think Ive got it now.
alias: Verwarming inschakelen lage prijs
description: Badkamer en hal
triggers:
- trigger: numeric_state
entity_id:
- sensor.nordpool_lowest_price
below: 0.02
entity_id:
- sensor.panasonic_heat_pump_main_outside_temp
below: 16
conditions: []
actions:
- action: climate.set_hvac_mode
metadata: {}
hvac_mode: heat
entity_id:
- climate.0xa4c1383076cd079e
- climate.0xa4c138c5b4282419
mode: single
