NordPool integration stops updating after HA supervisor update
Every time HA supervisor updates, NordPool integration (GitHub - custom-components/nordpool: This component allows you to pull in the energy prices into Home-Assistant.) stops updating until HA is restarted.
I am not sure if this should be reported to maintainer of NordPool integration or supervisor needs to run HA restart as gereral rule.
Any ideas?
Thanks!
Best regards,
Mario.
Update Nordpool in HACS. I had the same problem. After update nodlrpool works
When NordPool integration is up2date, and HA supervisor update pops up, after HA supervisor updates, NordPool integration simply stops providing new values.
There is no new update for NordPool integration at that point. What did you mean by updating NordPool in HACS?
Best regards,
Mario.
Does not help. Anything else?
IMHO it is not related to supervisor in any way :slight_smile: but to NPS API change from oct 14 :frowning:
When You update to 0.0.15 nordpool custom component it creates new entities, so under Settings-> Devices…-> Entities delete old unavailable ones and rename new to old to keep all automations etc.
Worked for me :slight_smile:
Best, JR
I am aware chages in API from this month. However, this issue bothers me in some months now and has nothing to do with recent API and sensor name changes.
I was just too busy to properly open a topic here to discuss it.
Best regards,
Mario.
what is this error?
Config was used from nordpool, this is a deprecated alias which will be removed in HA Core 2025.11. Use homeassistant.core_config.Config instead, please report it to the author of the ‘nordpool’ custom integration
