Norman TDBU blind control
I recently outfitted my house with motorised Norman top down bottom up (TDBU) cellular shades.
They offer a hub but unfortunately it only exposes the bottom rail to third party controllers like Google Home, Alexa, and Homekit.
I successfully connected the hub to Home Assistant via the Homekit Device integration and confirmed that I only have control of the bottom rail.
Hobbled.
Attempting to set the cover to any position immediately sends the top rail to the closed position at the top of the blind and only controls the position of the bottom rail.
This would be fine for single rail blinds but for TDBU it is annoying as for best privacy while maintaining my view my blinds need the middle/top rail set anywhere from 30 to 50%.
It is also unfortunate as their app has control of both rails and reports the motor battery state. The excuse from the manufacturer in their documentation is that third party controllers do not understand the concept of a middle or top rail. This is rubbish it could be exposed as a second cover. The blind itself takes care of the maximum possible positions. And there is no excuse for not exposing the battery sensor.
To gain better control I spent an entire day hacking a QuinLED ESP32 into the remote battery compartment to press the buttons for me.
This was especially tedious and fiddly as I chose to maintain the remote functionality and did not solder directly to the pushbutton pads but to the 0603 SMD components (1.55mm x 0.85mm) on the back of the PCB with fine wire wrap wire. This took a very steady hand and a stereo microscope. On the plus side none of the buttons or LEDs were multiplexed so I could use the ESP open drain outputs and GPIO inputs directly and the remote can be powered from the ESP 3.3V supply.
After some confusion with the active state of the open drain outputs (they are normally low impedance and go high impedance when active), I got it working. It has feedback of which blinds are currently selected for control:
Due to the limited number of i/o I dropped the top left and right favourite buttons on the remote (fully open and fully close) as these can be accomplished with the other buttons and a script. The favourite (star) button was added as this is a quick way to set my preferred open state of the blind (it is able to be set in the blind itself).
ESPHome config if you are interested: dining-blinds.yaml (4.3 KB)
I have the kitchen and dining rooms opening and closing the blinds automatically at sunrise/sunset and have some shortcut scripts for manual control that I am reasonably happy with:
Screenshot 2024-03-18 at 10-05-27 Overview – Home Assistant
Unfortunately as there is no state feedback I can not show which state is currently active as recording this in an input text or input select would get out of sync as soon as the physical remote was used.
Due to the laborious and fiddly nature of this hack (It really did take a whole day for one remote) and the fact that there was no cover state feedback I started looking at the nRF52840 Bluetooth SoC in the remote.
After only half an hour of failed Bluetooth scanning using the nRF Connect phone app I realised why this was a dead end:
Bastarrds!
They aren’t using Bluetooth but are using a custom 2.4GHz protocol instead. :face_with_symbols_over_mouth:
So, where to from here?
I could hack ESP boards into another five remotes for the remaining rooms. I really loath that prospect.
Or I could start looking at hacking their hub to see what it exposes over the Ethernet port using wireshark. Particularly when it is controlling the top rail. Or see if it has any interesting exposed test ports inside.
Or I could investigate where the interesting unpopulated ports and test points on the remote connect to on the nRF chip:
To be continued…
Wow!
I interface with my blinds via RF. But I have some thoughtfully placed door sensors / super magnets to detect “Fully open”. That helps a fair bit.
Boo!
Ditched the “keep the remote control function” idea and soldered directly to the remaining remote button pads. I completed each one in less than an hour.
I’m interested in copying essentially this same exact project with the Norman remote, except I’ll only be controlling one roller shade (so not tdbu) and only really care about the close and open buttons (though adding the up/down would be nice). Mostly because it seems like a fun project and my dealer is trying to charge $300 (!!!) for the smart hub
I’m a bit of an electronics noob so have a few questions…
Anything I should be looking for specifically in an esp32 board? or would something like this work? SparkFun Qwiic Pocket Development Board - ESP32-C6 - DEV-22925 - SparkFun Electronics
What does soldering to the remote pads look like (I don’t care about losing remote functionality)? And how did you power it?
Any ESP32 should work*.
ESP8266 boards don’t have enough GPIO.
I have to open up my controllers to clone a couple of new remotes later this week. I’ll take some photos.
* I power the ESP32 from a 5V plug pack. I connected the 3V3 supply from the ESP32 to the battery contacts of the remote. So you will need a good quality ESP32. Some have very under-powered voltage regulators. There are some recommendations here: What's your favourite ESP32 board? (# Best, good, cheap, quality, reliable)
This is the QuinLED ESP32 board I used:
esp32
Here are the connections on that board (oriented for the picture above):
Untitled2
D2R refers to the right hand side of the LED labelled D2 on the remote (trickiest thing to solder). The SWn labels correspond to the pad labels on the remote.
This gives me these controls:
Untitled3
ESPHome yaml file:
lounge-blinds.yaml (4.4 KB)
Thank you so much for the thorough reply! Going to order some parts and look forward to seeing the pics!
Note the orange wires going to the LEDs, they’re the hardest.
Just coming back to say thanks again! I used the usb to power the board and remote and really only need the open/close buttons so mine’s a lot simpler but it does the trick for me!
I have new install of Norman shades with the hub and Shadeauto app & experience similar issue. I can’t believe the poor integration with Alexa/smarthome - and near-zero documentation. I msg Norman and they don’t want to answer - say contact the dealer. The dealer says they don’t/can’t support these integrations. Norman = bad customer service / bad business attitude.
But, reason for post - there is a workaround that gives at least some functionality for top-down smart home - and that is to create a scene in the Shadeauto app for each scenario that you may want. A scene sets shade positions for all shades in a room. So, there is no choice on a scene to control only some of the shades in a room - have to set all. Once a scene has been created, the scene name is recognized by [Alexa] - and have to say ‘Alexa, Start [scene name]’ or 'Alexa, Run [scene name].
But, this is kludgy and developer of app should fix the app and provide documentation to users! As far as I can tell, you can’t even STOP a shade from moving with a voice command - ridiculous!
Tom, given that you can program the Norman remote to operate multiple blinds - eg one on each of the 5 channel keys - would it be an option to add all your blinds to one ‘master’ remote, and then have the ESP32 select the channel for an individual blind, or ‘all’, rather than hack multiple remotes, each with their own ESP32?
No. The remote has 5 channels. I have 20+ blinds.
Also these are spread over a large house and the remote range is terrible.
Any one know where to get an extra remote?
Contact whoever sold you the shades.
I’m trying to automate the same thing, so I’ll just dump some extra research here:
  • the hub uses Dexatek’s IoT system
  • it integrates with AWS IoT
  • the hub publishes its local and multicast address on mDNS as _nien_made._tcp. (“NienMadeLocal”)
  • the IoT id is visible in mdns, as thing_name=us-east-1:(some_uuid)_(some_opaque_string)
  • the IoT Thing definition definitely supports both bottom and middle rail independently
I’m not sure how the AWS authentication works yet.
Making any progress with this @viraptor ?
I hate reading decompiled Java :slight_smile:
I just got my SDR downconverter instead and hope to work on decoding the remote signals tomorrow.
(the actual mqtt auth is integrated with AWS Cogito, but I didn’t find out how the see the other devices starting with the login credentials)
More for the auth itself:
  • MQTT credentials come in through the Amplify framework
  • the userId gets printed out in logs somewhere. (not sure if readable with adb)
  • Amplify is configured with a Cognito pool, but it’s not trivial to find
In a perfect world, once the pool, region and identity pool id is known, it should be trivial to login with the app user/pass credentials.
It may take longer - AliExpress scammed me on that one, so I’m waiting for new hardware :confused:
Long time listener, first time caller. I have their Honecomb shades that come with the Gen 2 hub and have been tinkering a bit. The hub is kinda shit, but I’ve been able to enumerate some components and wanted to share some super early results:
  1. The Hub listens on tcp/22 (SSH, would love to guess that login), tcp/10123 (API Endpoint the mobile app communicates with when on the local network), and tcp/35701 (Flagged as IKEA Tradfri endpoint, could be interesting if the security code can be discovered).
  2. The shades seem to communicate over Zigbee on 2.4ghz, but I haven’t had a chance to play too much here. If that’s the case, and the messages can be reversed, the ideal state would be to directly pair the shades to your own Zigbee dongle and throw the hub in the trash. I need to spend time with my SDR here.
  3. The API is completely unauthenticated :roll_eyes:, but for some calls it does require knowing the IoT ID (referred to as ThingName) as @viraptor mentioned. But this can be obtained from a separate unauthenticated call. The API accepts an HTTP POST request that includes a JSON blob in the POST Body, and returns a JSON blob. That means writing an integration may not be too terribly difficult.
API Calls:
  1. Get ThingID & Other info - /NM/v1/registration
Post Body: {"Timestamp":<Unix timestamp>} - Because the API is terrible, you can honestly supply any numeric value.
Example w/ curl: curl -v -X POST -H "Content-Type: application/json" -d '{"Timestamp":"1744671634"}' http://<Hub IP Address>:10123/NM/v1/registration
Valuble Information: ThingName
Sample ThingName: us-east-1:f5e01ffe-8d30-4822-89ea-2b859ba371f3_11111111111111
  1. Get Shade information - /NM/v1/GetAllPeripheral
Post Body: {"ThingName":"<Value from Registration>","TaskID":<Any number>,"Timestamp":<Unix timestamp>}
Example w/ curl: curl -v -X POST -H "Content-Type: application/json" -d '{"ThingName":"<Value from Registration>>", "TaskID": 17654, "Timestamp": 1744670687}' http://<Hub IP Address>:10123/NM/v1/GetAllPeripheral
Valuble Information: PeripheralUID, ModuleType, ModuleDetail (I assume the latter 2 values identify the particular shade type)
  1. Get Shade status, including position & battery - /NM/v1/status
Example w/ curl: curl -v -X POST -H "Content-Type: application/json" -d '{"Timestamp":"1744671634"}' http://<Hub IP Address>:10123/NM/v1/status
Valuble Information: PeripheralUID, BatteryVoltage, TargetBottomRailPosition, TargetMiddleRailPosition, BottomRailPosition, MiddleRailPosition
  1. Control Shades - /NM/v1/control
Post Body: {"PeripheralUID":<Shade to control from GetAllPeripheral>,"Timestamp":<Unix timestamp>,"TaskID":<Any number>,"MiddleRailPosition":<0-100>,"BottomRailPosition":<0-100>>}
Example w/ curl: curl -v -X POST -H "Content-Type: application/json" -d '{"PeripheralUID":<11111>,"Timestamp":1744671710,"TaskID":1245,"MiddleRailPosition":100,"BottomRailPosition":50}' http://<Hub IP Address>:10123/NM/v1/control
When the mobile app makes a shade position call it includes additional info in the Post body but they seem to be optional, here’s the full body:
{"RoomID":11111,"PeripheralUID":11111,"Timestamp":1744672480,"TaskID":14198,"MiddleRailPosition":100,"GroupID":2,"BottomRailPosition":55}
Position values range from 0-100 with 100 being completely open and 0 being completely closed for Bottom Up and the inverse for Top Down. BottomRailPosition equates to the buttom up rail and MiddleRailPosition equates to the top down rail. At least with my TDBU shades, you must supply a position for both rails controling the shade even if you only intend to move one of them. In my above example, the shade will open to 50% leaving the top down rail unchanged. If the messages are the same for Zigbee, it would help a lot in terms of being able to toss the hub.
What makes you say that?
The remote uses a nRF52840 Bluetooth SoC which does not appear on any Bluetooth scanner as they seem to have implemented a proprietary control method (which the SoC supports).
