Nortek HUSBZB-1 stick with virtual machine
I’m using the Nortek HUSBZB-1 on virtual machine (intel NUC- Windows-VirtualBox) and everything function, but every time after restarting the NUC I need to reconnect the stick and restart home assistant via the server control section.
There’s something I can do to avoid this?
Thank You
I had the same problem using a HUSBZB-1 and VirtualBox as well. Sorry to say I never did resolve it, but suspected that VB was not assigning the USB port to the VM early enough in the boot up process. My solution was to forget VB and install Proxmox on the NUC as a VM host environment. I know this isn’t much help…
updating and re-installing VirtualBox and the Extension pack fix the issue
