Nortek HUSBZB-1 Zwave serial/by-id USB port path
I have a Nortek HUSBZB-1, which has both Zwave and Zigbee, that has been working fine for both since I first installed it about 4 months ago. I recently purchased a new Zwave sensor that shows as Unknown and was advised to download and edit open-zwave files then add a path to a zwave entry in my configuration.yaml file so that the device name shows up correctly
When I go to Supervisor>System>Host System>Menu>Hardware I see the following:
serial:
  - /dev/ttyUSB0
    /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_xxxxxxxx-if00-port0
  - /dev/ttyUSB1
    /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_xxxxxxxx-if01-port0
  - /dev/ttyAMA0
What is the path of the Nortek HUSBZB-1 Zwave? Is it if00-port0 or if01-port0?
IIRC if00 is zwave and if01 is zigbee
