I had Adax before (around 2016-ish), they were just as bad as the Mill ones (wifi gen 2) I have now. I haven’t tried Adax after 2016, they might be better now?
You could order a Namron one online, test it out for a week or so and return it on “angrerett” if it’s not working OK.
Without any other experience with other panelovner than Mill’s Gen 2 WiFi-connected ovn, i would probably buy a Namron one, all my other stuff from namron (Bulbs, lights and thermostats for my in-floor heating) are rock solid and easy to use
Namron’s only works with a proprietary hub and - as far as I can tell - subscription apps. I’m not sure about the latter, but I haven’t bee able to connect it to my hub (Ikea Dirigera) with any of the half dozen apps I’ve tried. In my view, that completely defeats the purpose of the Zigbee protocol, and for me the radiator is useless, so I hope to sell it for half price. Be warned.
I ended up with tha Adax Neo and 2nd gen. thermostat . The thermostat works well, but it does not have a backup logic, so works only when connected to WiFi.
Well, it may use Zigbee/zigbee2mqtt technology, but I haven’t been able to access the heater with any non-proprietary app, and I don’t subscribe to/pay for any proprietary ones. I had en email exchange with Elektroimportøren, the Norwegian retailer, and as far as I understood, the company confirmed there is no solution that doesn’t involve a paid subscription. To be honest, the person there wasn’t particularly helpful.
But if anyone knows how to access the heater through or with Home Assistant, I’d love to learn it!
Well since the 540139X is listed as a supported device in Z2M you can be pretty safe that it is supported without any proprietary Namron hub. Did you try to pair it with Z2M?
I’ve too had some e-mail exchanges with said company without getting any help.
On a sidenote the gen.2 Mills have been way easier to pair now after a firmware upgrade that made the pairing process use a built in hotspot in the heater. Before that it was a nightmare to get them connected to the wifi.
And you have added a piece of hardware (radio) to talk to Zigbee2MQTT, or did you just install the add-on?
Zigbee is a communication protocal that requires a hardware device and coordinator software that talks to the IOT device with a similar Zigbee radio.
It seems we’re back to square one. As I stated originally, it seems the Namron radiator can only been paired using proprietary hardware. I have a Dirigera hub and a Sonoff extender. Both work flawlessly with Home Assistant and all my devices - except for that Namron radiator, which is not recognized by any means or app I have tried.
So do you know of any particular non-proprietary hardware that allws pairing with the Namron radiator? Have you actually been able to do it?
You are misunderstanding. A Dirigera hub cannot work as a coordinator in a Zigbee2MQTT network. The question remains - why and how are you running Zigbee2MQTT if you are mixing the Dirigera hub into the equation? With a correct setup you would both not need the Dirigera hub and you would be able to pair your Namron heater (assuming it’s a supported version). You’ve already been linked information on how, what and why you run Z2M, please read it.
I have, and I’m sorry to say that neither it nor anything I’ve read here is helpful. Exactly what hardware/“correct setup” do I need to pair the Namron radiator? If you can’t give a straight answer, that’s okay, just say so.
You haven’t even clicked the link. Start there. Hint: “Get rid of your proprietary bridges” (Which the Dirigera is). You said you have Z2M installed, how are you using it? Surely it’s not with the Dirigera.
