I wanted to see the database size and backup folder size on my dashboard.
I managed to get the file size integration to work by adding /config directory to allowlist_external_dirs and then adding the Filesize integration and entering /config/home-assistant_v2.db.
Then I tried to add the Folder integration to watch the size of the /backup directory.
But when I try to add /backup to the allowlist_external_dirs and do a configuration check, I get an error.
Not a directory @ data[‘allowlist_external_dirs’][1]
Never mind, i’ve tried with both and various /folders , below /config i can “apply” whitelist_external_dirs … but not sensor: folder | folder: /backup … however i dont need it as i have Samba integration, and control my backups there ( they actually don’t fill so much anymore, about 1 GB in 3 month, and no reason to “store” for longer periods actually, considering the rapid changes HA is going through lately )
are you talking about the backups, HA does, prior to installing new “versions” ?
they are visible in /Settings/system/ backups
they are visible in add-on File_Editor ( un-tick " Enforce Basepath" in settings for file-editor ) , and you have access to the whole OS / ( including /backup )
they are visible on any devices, if you Install add-on Samba_Share
Sure they are visible on the backups page, but I would like to have a sensor telling me the total size of the folder. That would allow me to also see historical values.
I am not using the file editor add-on or samba share. I am duplicating them by fetching them with SFTP on another machine. But that is beside the point. I would like a sensor recording the size. It must be possible…?
