Hello
I recently switched my Internet service provider. Worst thing is they use CG-NAT and I am also not able to get static IPv4 to forward the port . Previously I was using cloudflared for haaska
alexa integration. After switching ISP I am having very hard time accessing HA . Cloudflare keep dropping the connection sometimes it works and sometimes it does not and so does the Alexa.
Tried many things to get it working like my current ISP provide port forwarding over IPv6 , with duckdns and lets encrypt I got external access over ipv6 but haaska
fails to connect , as far I know it does not work with ipv6
Also tried VPS to forward a port but that did not work out either.
I now finally installed the tailscale
with subnet-routes
in my home server . Connected tailscale
to a VPS. Installed cloudflared in the VPS and routed it to use tailscale subnet route to use homeassistant. As homeassistnat I also added my radarr , sonarr and plex sub domain to the tunnel . All other sub domains are working but homeassistant is not accessible . When I was using cloudflared addon I used http
trusted_proxies
. I added my tailscale VPS IP and my home server tailscale IP to my trusted_proxies
but I am still getting white blank page when I try to access HA.
This is my config.yaml for cloudflared
tunnel: 7b5d5ddb-f50f-477f-8bxx-xxxxxx
credentials-file: /root/.cloudflared/7b5d5ddb-f50f-477f-8bxx-xxxxxx.json
ingress:
- hostname: myxxxxx.xx
service: http://100.99.123.113:8123
- hostname: radarr.mymyxxxxx.xx
service: http://100.99.123.113:7878
- hostname: sonarr.mymyxxxxx.xx
service: http://100.99.123.113:8989
- hostname: qbit.mymyxxxxx.xx
service: http://100.99.123.113:8080
- hostname: plex.myxxxxx.xx
service: http://100.99.123.113:32400
- service: http_status:404
This is my configuration.yml
in homeassistant
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
- 100.106.103.33 #tailscale_VPS_IP
- 100.99.123.113 #tailscale_homeserver_IP
- 172.17.0.1
- 172.30.32.1
- 192.168.0.38
- 192.168.0.111 #homeserver_IP
- 198.xx.xx.xx. #VPS_IPv4
I do not understand what I am doing wrong , as the other domains are accessible that means cloudflared tunnel is working fine but only homeassistant is not accessible. Please help me with this
