Hi community,
I bought a Sonoff ZBBridge flashed to Tasmota, having a ZHA Profile enabled.
The Server is started properly on the device. When trying to add the Zigbee Home Automation in HomeAssistant 2023.9.1, there is when configuring the network just an Error dialog shown. The Zigbee Coordinator was not found and finishing adding the integration failed.
I see on the Sonoff in the console, that HomeAssistant connected successfully.
15:25:45.062 RUL: SYSTEM#BOOT performs “TCPStart 8888”
15:25:45.064 TCP: Starting TCP server on port 8888
15:25:45.066 RSL: RESULT = {“TCPStart”:“Done”}
15:25:48.476 QPC: Reset
15:25:49.433 RSL: STATE = {“Time”:“2023-09-10T15:25:49”,“Uptime”:“0T00:00:08”,“UptimeSec”:8,“Vcc”:3.462,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:0,“Wifi”:{“AP”:1,“SSId”:“WhiteRabbit”,“BSSId”:“78:45:58:E5:1B:5A”,“Channel”:11,“Mode”:“11n”,“RSSI”:52,“Signal”:-74,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
15:27:50.231 TCP: Got connection from 192.168.1.209
Any idea about this issue and how to solve it?
Thanks all!
In the HomeAssistant log I also found this error:
File “/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py”, line 166, in _ensure_network_running
raise NetworkNotFormed(“Node is not part of a network”)
zigpy.exceptions.NetworkNotFormed: Node is not part of a network
Note: This is the result, after adding the connection details wir EZSP hardware when the network shall get configured:
