I try to connect my ConbeeII dongle to ZHA.
I’m not able to get it running.
I do run HA supervised as a VM under Unraid.
If I do select the conbeeII to add to the VM.
and set up ZHA it is recognizing the conbeeII.
(It is showing as choice) after selecting it runs for a while and coming with a menu to select radio type.
I select Deconz.
After that I do have to add manually the path. At the and is not starting ZHA because it can not connect to the ConbeeII
After that I did install USB manager in Unraid and selected the Conbee to connect only serial.
Now I’m able to start ZHA .
But after starting and go to the radio entity it says:
The device is switched off by integration.
Any ideas how to integrate the ConbeeII to ZHA in HA VM?
