Very strange issue. I installed Home Assistant on a Raspberry Pi3 using Docker.
I used this guide.
Anyway I wanted to clean out and start over, with a fresh install, but no matter what I do it seems to keep my config.
I cleaned out the configuration directory, I purged docker.
rm -rf ~/docker/home-assistant/ha_config/*
docker container stop $(docker container ls -a -q) && docker system prune -a -f --volumes
I then run docker-compose to bring it up again, but when I go to the url: http://homeautopi:8123
I don’t get the create user page, instead I get:
You’re about to give http://homeautopi:8123/ access to your Home Assistant instance.
Logging in with Home Assistant Local .
And when I log in it has all my old things, for example extra settings I added for a Weather service.
I want to start completely fresh, how do I do that?
