Hi With the new interface of the xiaomi home apps I’m not able to activate the lan access
you have a DGNWG02LM ? right? LAN access is only available with this gateway.
I have the MiHome APP 5.9.19 of the 7 december 2020 and it still have the “LAN” menu, no change.
Hi Olivier
I really appreciate you helping me here my friend. Still no luck. Are you aware that the new ones do not allow you to go into the LAN access mode the old ones did? Sorry silly question but it was a surprise to me.
I have two of the ZHWG11LM gateways and I checked on my router. I checked that it describes the devices as Aqara_Hub-34cb and I copied and pasted the MAC into the automation you can see part of above (previous post). I also tried under developers tools - see image below. The same automation works with the other Aqara gateways I have except they are V3 and have the ports opened. I tried using the different MACs. The two that work in Dev tools and the two that don’t, the ones we are talking about here, don’t.
I have checked the correct MAC in the MiHome app
Below is from the HA logs.
Logger: homeassistant.components.automation.new_automation_2
Source: core.py:1399
Integration: Automation (documentation, issues)
First occurred: 19:14:34 (3 occurrences)
Last logged: 19:17:05
While executing automation automation.new_automation_2
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 404, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1026, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 242, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 250, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 457, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1399, in async_call
processed_data = handler.schema(service_data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 594, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.8/site-packages/voluptuous/schema_builder.py", line 432, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: Unknown gateway sid 54efxxxxx for dictionary value @ data['gw_mac']
Lan access is not an option for ZHWG11LM, so its normal you dont have this.
its only for DGNWG02LM.
Have you got a chinese version of ZHWG11LM? or EU ones?
I have chineses versions for the 5 xiaomi gateway i owned. Mainland China in the MiHome App config.
Everything is auto discovered in HA with the new integration Xiaomi Homekit.
Chek if its not EU version and yours setting are Mainland China in Xiaomi MiHome.
Hey Olivier
I am New Zealand so no chance they are European. Got them on Aliexpress. Yes the MiApp is on Mainland China.
Any other bright ideas?
B
Yes I have 2 of them
When I start to configure the 1st one I hade the old interface
After a update I get the New interface for sole device
My gateways are china version too
hello!
sorry to heard that…
Are the gateways are on the same network with the server of HA?
hello,
your screen capture look like from a ZHWG11LM not DGNWG02LM ???
dont understand…
Are you under Android or IOS?
I have the V3 aka DGNWG02LM
And I’m on a Xiaomi mi max 2 Android 9 I guess
As If said was on HA making the conf of the first gateways, taking the data from the old version of the app and its works and After un update I get the new interface
I now I Can’t get the token to add the second gateway
just check now and same as you! it seems Xiaomi have delete the lan access OPTION!!
!!!FOR ALL OTHERS USERS : DONT MAKE THE LAST FIRMWARE UPDATE!!!
its really sucks
Hi Olivier
Yes all is on the same network. I’m on Android. I just noticed that overnight the LAN option is removed for the DGNWG02LM. Last night I have the old interface for the DGNWG02LM and the new for the ZHWG11LM.
Yes the screen capture looks like the one above for the ZHWG11LM ones. I never got the old interface that I can remember.
In the XiaomiHome app I have the new interface like you have shown in your pictures for my ZHWG11LM.
In Home assistant in the HomeKit I have two devices. The integration says I have: Device info, ZHWG11LM, by Aqara, Firmware: 3.1.1
And for the other 2 Under the XiaomiMii intergration I have: Device info lumi.gateway.v3-MW300 by Xiaomi Firmware: 1.4.1_176. I checked on the back of the devices and they are both DGNWG02LM
So Just so I check through my process here. I simply added them to the MiHome app, they were autodiscovered by HA. I added them and can control them using HA (the light anyway) but cannot get them to make noises.
because lan mode is now deleted…understand now…
@bdb1 Have you been prompt for key when you integrate into HA? and which key have you wrote?
You have to buy a “HomeKit Compatible” and there will be a sticker on the box AND on the gateway : 8 digit that you will entered like this : XXX-XX-XXX.
Its the only solution…
Dont know if the ZHWG11LM still exist…
Yes I did but I cannot remember, sorry! Can you remember which one and I will confirm if that is what I put in?
like this : 16 digits :
Key : 889aqxxxxxhl5c77
XXX-XX-XXX. That is the code I entered. I remember that pattern and it was on the box.
Yes the HomeKit logo etc is on the box and gateway. I do not have HomeKit gear at all though. Does that matter? I only have HA, WIFI and Zigbee.
lucky you are because its a ZHWG11LM HOME KIT COMPATIBLE, so the “key” is on a sticker on the box.
No matter if you dont have HomeKit gear…i dont have too…lol…Apple stuff lol, never mind
perhaps i will buy a couple…if my 2 gateways DGNWG02LM stop working someday…
So when I installed I entered the code on the box and it all worked. That is where we got to and now as you know, no sounds! I just tried it again now hoping that maybe the latest HA update would make a difference and no luck.
Maybe I buy some more V3’s?
