Not able to par Z-wave devise after factory reset
I excluded one Z-Wave device and I suspect something went wrong in the process. I did a factory reset. When scanning with Z-Wave JS, the QR code, I get a Z-Wave JS message that the item is included and will appear when item is powered on. It doesn’t. Its not in the integration devise list.
After doing this 5-6 times without this working an several restarts of HA, I edited the core.config_entries/core.device_registry/core.entity_registry-files, removing all entries for this devise (so obviously the item had not been removed by the initial exclusion process.).
And I am stuck, can’t add the device to HA.
Here is the integration log after trying to add the device, a light dimmer. The other two dimmers went well.
Debug MODE:
Subscribed to Z-Wave JS Log Messages…
Log Level changed to: Debug
2023-09-13T14:27:56.777Z SERIAL « 0x011800a800000100020a3202213400000036000000b8007f7fed              (26 bytes)
2023-09-13T14:27:56.779Z SERIAL » [ACK]        (0x06)
2023-09-13T14:27:56.780Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:27:56.782Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 4 => 5.4                     [Endpoint 0]
2023-09-13T14:27:56.783Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -72 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      5.4
                                      time delta: 0 seconds
2023-09-13T14:27:56.953Z SERIAL « 0x011800a800000100020a3202a104000000eb000000b9007f7f81              (26 bytes)
2023-09-13T14:27:56.954Z SERIAL » [ACK]        (0x06)
2023-09-13T14:27:56.956Z CNTRLR   [Node 002] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2023-09-13T14:27:56.957Z CNTRLR   [Node 002] [~] [Meter] value[66561]: 236 => 235                   [Endpoint 0]
2023-09-13T14:27:56.958Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      235
2023-09-13T14:27:57.152Z SERIAL « 0x011800a800000100020a3202a16c00000070000000b9007f7f72              (26 bytes)
2023-09-13T14:27:57.153Z SERIAL » [ACK]        (0x06)
2023-09-13T14:27:57.155Z CNTRLR   [Node 002] [Meter] value[66817]: metadata updated                 [Endpoint 0]
2023-09-13T14:27:57.156Z CNTRLR   [Node 002] [~] [Meter] value[66817]: 0.109 => 0.112               [Endpoint 0]
2023-09-13T14:27:57.157Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      A
                                      rate type:  Consumed
                                      value:      0.112
2023-09-13T14:27:57.765Z DRIVER   all queues busy
2023-09-13T14:27:57.767Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2023-09-13T14:27:57.768Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-09-13T14:27:57.770Z SERIAL « [ACK]        (0x06)
2023-09-13T14:27:57.772Z SERIAL « 0x0107013b9994947f24                                                 (9 bytes)
2023-09-13T14:27:57.773Z SERIAL » [ACK]        (0x06)
2023-09-13T14:27:57.774Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -103 dBm
                                    channel 1: -108 dBm
                                    channel 2: -108 dBm
2023-09-13T14:27:57.776Z DRIVER   all queues idle
2023-09-13T14:27:57.778Z SERIAL « 0x011800a800000100020a3202213400000026000000b9007f7ffc              (26 bytes)
2023-09-13T14:27:57.780Z SERIAL » [ACK]        (0x06)
2023-09-13T14:27:57.782Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:27:57.784Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 5.4 => 3.8                   [Endpoint 0]
2023-09-13T14:27:57.785Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      3.8
2023-09-13T14:27:57.952Z SERIAL « 0x011800a800000100020a3202a104000000ec000000b9007f7f86              (26 bytes)
2023-09-13T14:27:57.953Z SERIAL » [ACK]        (0x06)
2023-09-13T14:27:57.955Z CNTRLR   [Node 002] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2023-09-13T14:27:57.956Z CNTRLR   [Node 002] [~] [Meter] value[66561]: 235 => 236                   [Endpoint 0]
2023-09-13T14:27:57.957Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      236
2023-09-13T14:27:58.153Z SERIAL « 0x011800a800000100020a3202a16c0000006e000000b8007f7f6d              (26 bytes)
2023-09-13T14:27:58.154Z SERIAL » [ACK]        (0x06)
2023-09-13T14:27:58.157Z CNTRLR   [Node 002] [Meter] value[66817]: metadata updated                 [Endpoint 0]
2023-09-13T14:27:58.158Z CNTRLR   [Node 002] [~] [Meter] value[66817]: 0.112 => 0.11                [Endpoint 0]
2023-09-13T14:27:58.159Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -72 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      A
                                      rate type:  Consumed
                                      value:      0.11
2023-09-13T14:28:11.778Z SERIAL « 0x011800a800000100020a3202213400000036000000b9007f7fec              (26 bytes)
2023-09-13T14:28:11.781Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:11.785Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:11.788Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 3.8 => 5.4                   [Endpoint 0]
2023-09-13T14:28:11.791Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      5.4
2023-09-13T14:28:11.954Z SERIAL « 0x011800a800000100020a3202a104000000eb000000b9007f7f81              (26 bytes)
2023-09-13T14:28:11.956Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:11.960Z CNTRLR   [Node 002] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:11.963Z CNTRLR   [Node 002] [~] [Meter] value[66561]: 236 => 235                   [Endpoint 0]
2023-09-13T14:28:11.966Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      235
2023-09-13T14:28:12.154Z SERIAL « 0x011800a800000100020a3202a16c00000070000000b9007f7f72              (26 bytes)
2023-09-13T14:28:12.156Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:12.159Z CNTRLR   [Node 002] [Meter] value[66817]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:12.162Z CNTRLR   [Node 002] [~] [Meter] value[66817]: 0.11 => 0.112                [Endpoint 0]
2023-09-13T14:28:12.165Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      A
                                      rate type:  Consumed
                                      value:      0.112
2023-09-13T14:28:12.778Z SERIAL « 0x011800a800000100020a3202213400000025000000b9007f7fff              (26 bytes)
2023-09-13T14:28:12.781Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:12.785Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:12.788Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 5.4 => 3.7                   [Endpoint 0]
2023-09-13T14:28:12.791Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      3.7
2023-09-13T14:28:12.953Z SERIAL « 0x011800a800000100020a3202a104000000eb000000b9007f7f81              (26 bytes)
2023-09-13T14:28:12.956Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:12.959Z CNTRLR   [Node 002] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:12.962Z CNTRLR   [Node 002] [~] [Meter] value[66561]: 235 => 235                   [Endpoint 0]
2023-09-13T14:28:12.965Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      235
2023-09-13T14:28:13.153Z SERIAL « 0x011800a800000100020a3202a16c0000006e000000b9007f7f6c              (26 bytes)
2023-09-13T14:28:13.156Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:13.159Z CNTRLR   [Node 002] [Meter] value[66817]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:13.164Z CNTRLR   [Node 002] [~] [Meter] value[66817]: 0.112 => 0.11                [Endpoint 0]
2023-09-13T14:28:13.166Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      A
                                      rate type:  Consumed
                                      value:      0.11
2023-09-13T14:28:17.778Z SERIAL « 0x011800a800000100020a3202213400000033000000b9007f7fe9              (26 bytes)
2023-09-13T14:28:17.781Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:17.785Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:17.788Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 3.7 => 5.1                   [Endpoint 0]
2023-09-13T14:28:17.791Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      5.1
2023-09-13T14:28:17.953Z SERIAL « 0x011800a800000100020a3202a104000000ec000000b9007f7f86              (26 bytes)
2023-09-13T14:28:17.954Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:17.956Z CNTRLR   [Node 002] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:17.958Z CNTRLR   [Node 002] [~] [Meter] value[66561]: 235 => 236                   [Endpoint 0]
2023-09-13T14:28:17.959Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      236
2023-09-13T14:28:18.153Z SERIAL « 0x011800a800000100020a3202a16c00000071000000b9007f7f73              (26 bytes)
2023-09-13T14:28:18.154Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:18.156Z CNTRLR   [Node 002] [Meter] value[66817]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:18.158Z CNTRLR   [Node 002] [~] [Meter] value[66817]: 0.11 => 0.113                [Endpoint 0]
2023-09-13T14:28:18.159Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      A
                                      rate type:  Consumed
                                      value:      0.113
2023-09-13T14:28:18.778Z SERIAL « 0x011800a800000100020a3202213400000026000000b9007f7ffc              (26 bytes)
2023-09-13T14:28:18.779Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:18.781Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:18.783Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 5.1 => 3.8                   [Endpoint 0]
2023-09-13T14:28:18.784Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ RSSI: -71 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      3.8
2023-09-13T14:28:18.906Z CNTRLR   Leaving Smart Start listening mode...
2023-09-13T14:28:18.909Z DRIVER   all queues busy
2023-09-13T14:28:18.912Z SERIAL » 0x0105004ac50075                                                     (7 bytes)
2023-09-13T14:28:18.913Z DRIVER » [REQ] [AddNodeToNetwork]
                                    action:       Stop
                                    high power:   true
                                    network wide: true
                                    callback id:  0
2023-09-13T14:28:18.919Z SERIAL « [ACK]        (0x06)
2023-09-13T14:28:18.927Z CNTRLR   Left Smart Start listening mode
2023-09-13T14:28:18.929Z CNTRLR   Starting inclusion process with strategy Default...
2023-09-13T14:28:18.941Z SERIAL » 0x0105004ac12253                                                     (7 bytes)
2023-09-13T14:28:18.944Z DRIVER » [REQ] [AddNodeToNetwork]
                                    node type:    Any
                                    high power:   true
                                    network wide: true
                                    callback id:  34
2023-09-13T14:28:18.951Z SERIAL « [ACK]        (0x06)
2023-09-13T14:28:18.953Z SERIAL « 0x0108004a22010000009e                                              (10 bytes)
2023-09-13T14:28:18.955Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:18.957Z DRIVER « [REQ] [AddNodeToNetwork]
                                    status:      Ready
                                    callback id: 34
2023-09-13T14:28:18.961Z CNTRLR   The controller is now ready to add nodes
2023-09-13T14:28:18.973Z DRIVER   all queues idle
2023-09-13T14:28:21.984Z SERIAL « 0x011800a814000100020a3202a104000000eb000000b20000009e              (26 bytes)
2023-09-13T14:28:21.988Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:21.993Z CNTRLR   [Node 002] [Meter] value[66561]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:21.997Z CNTRLR   [Node 002] [~] [Meter] value[66561]: 236 => 235                   [Endpoint 0]
2023-09-13T14:28:22.000Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -78 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      V
                                      rate type:  Consumed
                                      value:      235
2023-09-13T14:28:27.766Z DRIVER   all queues busy
2023-09-13T14:28:27.772Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2023-09-13T14:28:27.773Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-09-13T14:28:27.777Z SERIAL « [ACK]        (0x06)
2023-09-13T14:28:27.780Z SERIAL « 0x0107013b9995957f24                                                 (9 bytes)
2023-09-13T14:28:27.783Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:27.786Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -103 dBm
                                    channel 1: -107 dBm
                                    channel 2: -107 dBm
2023-09-13T14:28:27.791Z DRIVER   all queues idle
2023-09-13T14:28:29.389Z SERIAL « 0x011800a814000100020a3202213400000036000000b1000000f0              (26 bytes)
2023-09-13T14:28:29.392Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:29.396Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:29.399Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 3.8 => 5.4                   [Endpoint 0]
2023-09-13T14:28:29.401Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -79 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      5.4
2023-09-13T14:28:38.674Z SERIAL « 0x013000a81400010008229f035c00fbd8d23565a7d2a6f162b6bd36d4929093f52 (50 bytes)
                                  4f9f1f7286ffd586a4bba7200a300000087
2023-09-13T14:28:38.680Z DRIVER   Dropping message with invalid payload
2023-09-13T14:28:38.682Z DRIVER « [Node 008] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -93 dBm
                                  └─[Security2CCMessageEncapsulation] [INVALID]
                                      error: Multicast frames without MGRP extension
2023-09-13T14:28:38.684Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:41.078Z SERIAL « 0x013000a81400010008229f035d007ca912fcf59362cbd4ebc0f9e7148af303d09 (50 bytes)
                                  fe27c7dfe8d78c27c743f7300a200000061
2023-09-13T14:28:41.082Z DRIVER   Dropping message with invalid payload
2023-09-13T14:28:41.083Z DRIVER « [Node 008] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -94 dBm
2023-09-13T14:28:41.085Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:43.458Z SERIAL « 0x012c00a814000100081e9f035e001ff86c29d4b62af634646842706f839adf9de (46 bytes)
                                  3f42c5ceefaaa1e00a2000000fd
2023-09-13T14:28:43.462Z DRIVER   Dropping message with invalid payload
2023-09-13T14:28:43.464Z DRIVER « [Node 008] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -94 dBm
2023-09-13T14:28:43.466Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:43.734Z SERIAL « 0x012c00a814000100081e9f035e001ff86c29d4b62af634646842706f839adf9de (46 bytes)
                                  3f42c5ceefaaa1e009f000000c0
2023-09-13T14:28:43.736Z DRIVER   Dropping message with invalid payload
2023-09-13T14:28:43.737Z DRIVER « [Node 008] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -97 dBm
2023-09-13T14:28:43.738Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:45.923Z SERIAL « 0x011800a814000100020a3202213400000037000000b2000000f2              (26 bytes)
2023-09-13T14:28:45.925Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:45.927Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:45.928Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 5.4 => 5.5                   [Endpoint 0]
2023-09-13T14:28:45.930Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -78 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      5.5
2023-09-13T14:28:46.074Z SERIAL « 0x012800a814000100081a9f035f00af5b9aed6261558f5ac1c76a8da2ef4b303ff (42 bytes)
                                  ba1365b00a3000000c7
2023-09-13T14:28:46.076Z DRIVER   Dropping message with invalid payload
2023-09-13T14:28:46.077Z DRIVER « [Node 008] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -93 dBm
2023-09-13T14:28:46.078Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:52.622Z SERIAL « 0x011800a814000100020a3202213400000031000000b2000000f4              (26 bytes)
2023-09-13T14:28:52.625Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:52.628Z CNTRLR   [Node 002] [Meter] value[66049]: metadata updated                 [Endpoint 0]
2023-09-13T14:28:52.631Z CNTRLR   [Node 002] [~] [Meter] value[66049]: 5.5 => 4.9                   [Endpoint 0]
2023-09-13T14:28:52.634Z DRIVER « [Node 002] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -78 dBm
                                  └─[MeterCCReport]
                                      type:       Electric
                                      scale:      W
                                      rate type:  Consumed
                                      value:      4.9
2023-09-13T14:28:54.194Z SERIAL « 0x012800a814000100081a9f036100535ebb5a0b22b13fc153d139798b206839d1c (42 bytes)
                                  24d33b200a20000004a
2023-09-13T14:28:54.197Z DRIVER   Dropping message with invalid payload
2023-09-13T14:28:54.199Z DRIVER « [Node 008] [REQ] [BridgeApplicationCommand]
                                  │ type:        broadcast
                                  │ target node: 255
                                  │ RSSI:        -94 dBm
2023-09-13T14:28:54.201Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:57.764Z DRIVER   all queues busy
2023-09-13T14:28:57.769Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2023-09-13T14:28:57.771Z DRIVER » [REQ] [GetBackgroundRSSI]
2023-09-13T14:28:57.776Z SERIAL « [ACK]        (0x06)
2023-09-13T14:28:57.779Z SERIAL « 0x0107013b9995957f24                                                 (9 bytes)
2023-09-13T14:28:57.781Z SERIAL » [ACK]        (0x06)
2023-09-13T14:28:57.784Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -103 dBm
                                    channel 1: -107 dBm
                                    channel 2: -107 dBm
2023-09-13T14:28:57.789Z DRIVER   all queues idle
