Not able to program/communicate with esp_ir_tr module (ESP8285 all in one IR/TR) to program
Has anyone programmed one of these ESP_IR_TR all-in-one modules successfully? I’ve connected it to my USB to Serial board (PL2303HX chip) but it will not communicate with the device (using Chrome, which has worked fine before). I have previously programmed individual ESP01M modules for relays but with a different board. This all-in-one module uses 5V which my serial board provides (validated with meter) and I’ve reversed the TX/RX pins. I’ve also kept the jumper on when trying to program (and tried it without, disconnecting power each time).
esp_ir_tr
esp_ir_tr_rear
Just for anyone that might try to use this module, I was finally able to get ESPHOME on it using a CH340 TTL usb module.
Here is my code that is working to dump IR codes received:
esphome:
  friendly_name: IRremote1
esp8266:
  board: esp8285
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "???"
ota:
  password: "???"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Irremote1 Fallback Hotspot"
    password: "???"
captive_portal:
remote_receiver:
  pin:
    number: GPIO14
    inverted: true
  dump: all
#Transmit section once you used receiver to get codes
remote_transmitter:
  pin: GPIO4
  carrier_duty_percent: 50%
# Example to turn on/off a Hisense TV
button:
    on_press:
      - remote_transmitter.transmit_pioneer:
          rc_code_1: 0x2008
Edited: Added code block to setup transmitter with correct pin and example of one used for my Hisense TV
I like the form factor of those little things. A good way to get started with ESPHome IR.
Although I guess not having usb makes it more complex for new users.
Easy solution to this is to add a micro usb board (for power anyhow) and 3d print a case for both. This is what I’m doing, just have to shorten my jumpers. Since it’s updating over the air, no need to do more.
Could also cut a usb cable and either solder the wires directly or crimp on some Duponts. Especially once the initial flash is done.
I do like those usb breakouts too though.
Looking good!
@jumon & @Mahko_Mahko
Hello :wave:
Did you manage to get anything more out of these boards?
I’d like to use them as simple IR blasters, but before I go down a rabbit hole, I’m looking for guidance or warnings from you.
I found this HA post
Does it follow on from your post here?
I have it working, yes. It’s been a long time, so I can’t remember the physical connections I made, but here’s the code. It does show the pin I use to send and receive.
#2.6.2024: Endret den faste IP-adressen
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
wifi:
  use_address: 192.168.2.150
  networks:
  - ssid: "YOUR_SSID"
    password: "YOUR_PASSWORD"
    manual_ip:
      static_ip: 192.168.2.150
      gateway: 192.168.2.1
      subnet: 255.255.255.0
captive_portal:
logger:
  level: VERBOSE
ota:
  platform: esphome
web_server:
remote_receiver:
  pin:
    number: 23
    inverted: true
#  dump: pioneer
  dump: all
remote_transmitter:
  pin: 22
button:
    on_press:
          rc_code_1: 0xB51A
    on_press:
          rc_code_1: 0xB50A
    on_press:
          rc_code_1: 0xB50B
Yes, they work well. You can use the module and code I put above to receive your remote codes and then use those to remotely control anything supported by adding the code below:
remote_transmitter:
  pin: GPIO4
button:
    on_press:
          rc_code_1: 0x2008
That’s amazing
I’ll get to work on it :partying_face:
