Not Able to See my Broadlink RM pro Remote in front End
I can’t find the way how to display broad link switches (RM Pro remote) at the Front end?
I can receive and send the packet via Services page, but can’t display at frontend.
below is my Configurator File details:
switch 03:
platform: broadlink
host: 192.168.1.2
mac: ‘78:0f:77:00:ac:fa’
timeout: 115
friendly_name: Broadlink Universal Remote
switches:
tv_micromax:
friendly_name: “Micromax Tv Power”
command_on: ‘JgBYAAABLpQTExQSEhMTExQSEhMUNhQSEzcSOBM3EzcTNxM3ExMUNhMTEjgUERQSEzcUEhITExMTNxMTEjgSOBITEzcTNxM4EgAFJgABL0kUAAxgAAEuSxQADQU=’
command_off: ‘JgBYAAABL5QUEhQSExMSExMTFBITNxMTEzcTNxM3EzcUNxI4ExITNxMTFDYTExMTEjgUEhITExMTNxMTEzcUNhQSEjgUNhI4EwAFJQABL0oTAAxhAAEwSRQADQU=’
Below is the error I get while validating the configuration:
Component not found: tv_micromax
Invalid config for [switch.broadlink]: expected a dictionary for dictionary value @ data[‘switches’]. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/switch.broadlink/
Please help how to resolve the same
Thanks in advance
You need to update your post using code blocks (see the blue box at the top of the topic) or use the </> button.
You need to remove the friendly name I think. That was a breaking change a while back
Thanks a lot ill try
