I’ve got Arlo configured with my HA install, but I’m not having much luck with the arm/disarm/home actions.
My config for the Arlo alarm is as follows;
alarm_control_panel:
- platform: arlo
home_mode_name: Motion
away_mode_name: Armed
night_mode_name: Motion
I’ve read the install instructions as using the actual name for the mode, in the past I’ve had a Node.js based system which needed to use mode0, mode1 and mode2 as the state identifier. Motion is the name of my custom mode which basically doesn’t record anything, just ensures the motion is still detected.
My automation looks as follows;
- id: '1572603701074'
alias: Test Arm
description: ''
platform: webhook
webhook_id: test_arm
service: alarm_control_panel.alarm_arm_away
entity_id: alarm_control_panel.arlo
And nothing happens when the webhook is called. The automation is triggering, the alarm state is not actioning.
Not sure if I’m missing something obvious. At the moment I’ve got it working by calling a REST API back to my old node.js system to change the alarm state. I’d like to move all the functionality over to HA if possible.
