Not able to start home assistant
After good year running home assistant. Networkcable got damaged but removed all cables and restarted nuc.
But now the nuc keeps on saying no bootable drive found.
For me it is a bit stupid that you cant restart nuc after it has been installed.
So more people complain about this. Nuc is seeing the drive but it cant find a bootable image on it.
So it refuse to start home assistant.
Did all like mentioned in home assistant to download the os on a ssd. Installed it and last year all was working fine. But straingly not anymore.
Is there still a way to force nuc start up home assistant
Did you check that the BIOS settings are still correct?
Yep uefi boot is ensbled and secure boot is disabled.
But think ssd has more issues, because was able to boot from usb. This to install proxmox. But failed to install on that ssd, bad diskspace/partition on it
