19-03-13 04:22:10 ERROR (SyncWorker_0) [hassio.docker] Can’t create container from addon_core_ssh: 409 Client Error: Conflict (“Conflict. The container name “/addon_core_ssh” is already in use by container “2f74735538b99a824b2fdd67f3e3a103c329de5283399a1706650fb9be396025”. You have to remove (or rename) that container to be able to reuse that name.”)
19-03-15 02:43:01 ERROR (SyncWorker_13) [hassio.docker] Can’t create container from addon_core_ssh: 409 Client Error: Conflict (“Conflict. The container name “/addon_core_ssh” is already in use by container “2f74735538b99a824b2fdd67f3e3a103c329de5283399a1706650fb9be396025”. You have to remove (or rename) that container to be able to reuse that name.”)
Can’t seem to find "The container name “/addon_core_ssh” " in Portainer
got it. Just upgraded from 0.87.1 to 0.89.2, but still can’t start SSH:
19-03-16 17:02:20 ERROR (SyncWorker_18) [hassio.docker] Can’t create container from addon_core_ssh: 409 Client Error: Conflict (“Conflict. The container name “/addon_core_ssh” is already in use by container “2f74735538b99a824b2fdd67f3e3a103c329de5283399a1706650fb9be396025”. You have to remove (or rename) that container to be able to reuse that name.”)
completely uninstalled SSH, full rebooted, reinstalled SSH, but still refused to start with the same error:
19-03-16 17:31:14 ERROR (SyncWorker_2) [hassio.docker] Can’t create container from addon_core_ssh: 409 Client Error: Conflict (“Conflict. The container name “/addon_core_ssh” is already in use by container “2f74735538b99a824b2fdd67f3e3a103c329de5283399a1706650fb9be396025”. You have to remove (or rename) that container to be able to reuse that name.”)
Please provide the steps to fix it manually. Thanks in advance!
