Trying to update to the latest HSC 107.1 but no luck.
When pushing the update button in Lovelace Supervisor the circle go’s around and after a while it gives “Error: Unknown Error, see logs#”
“20-03-19 11:28:30 ERROR (SyncWorker_5) [supervisor.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.107.1 -> 404 Client Error: Not Found (“no such image: homeassistant/qemux86-64-homeassistant:0.107.1: No such image: homeassistant/qemux86-64-homeassistant:0.107.1”).
20-03-19 11:28:30 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails”
Not sure if this will help anyone else, but I was able to get the upgrade to run by freeing up space in my host system’s /var partition. I used this as a guide:
Jump down to the 3rd option, “Clean up APT cache in Ubuntu”. I did the
sudo apt-get autoclean
command and it opened up enough space to allow me to run the update.
I had the same root partition (/backup) was 100% it was my backups were not being delete. I manaually deleted the files and then I was able to create new backup and then update. Hope this helps:
How I found this:
Logon to hassio (SSH) as root
run Linux command df
