I am using an 8-button free pad, the button 1 to 4 are working those will fire an event without any problem the buttons 5 to 8 not firing any event data
Home assistant device diagnostics
"home_assistant": {
"installation_type": "Home Assistant Container",
"version": "2022.10.5",
"dev": false,
"hassio": false,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"timezone": "UTC",
"os_name": "Linux",
"os_version": "5.18.0-kali7-amd64",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.34.2",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.83",
"zigpy-deconz==0.19.0",
"zigpy==0.51.3",
"zigpy-xbee==0.16.2",
"zigpy-zigate==0.10.2",
"zigpy-znp==0.9.1"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 49976,
"manufacturer": "modkam.ru",
"model": "DIYRuZ_FreePad",
"name": "modkam.ru DIYRuZ_FreePad",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 0,
"power_source": "Battery or Unknown",
"lqi": 65,
"rssi": null,
"last_seen": "2022-10-27T10:11:30",
"available": true,
"device_type": "EndDevice",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=0, maximum_buffer_size=80, maximum_incoming_transfer_size=160, server_mask=0, maximum_outgoing_transfer_size=160, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0006",
"in_clusters": [
"0x0000"
"out_clusters": [
"0x0006",
"0x0008",
"0x0012",
"0x0300"
"2": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"3": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"4": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"5": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0008",
"0x0012",
"0x0300"
"6": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"7": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"8": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"9": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0008",
"0x0012",
"0x0300"
"10": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"11": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"12": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"13": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0008",
"0x0012",
"0x0300"
"14": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"15": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"16": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"17": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0008",
"0x0012",
"0x0300"
"18": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"19": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"20": {
"profile_id": 260,
"in_clusters": [],
"out_clusters": [
"0x0006",
"0x0012"
"active_coordinator": false,
"entities": [],
"neighbors": [],
"endpoint_names": [
"name": "REMOTE_CONTROL"
"user_given_name": null,
"device_reg_id": "049629de53bc6753e6e007adbc3e7238",
"area_id": null,
"cluster_details": {
"20": {
"device_type": {
"name": "REMOTE_CONTROL",
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {},
"unsupported_attributes": {}
"0x0012": {
"endpoint_attribute": "multistate_input",
"attributes": {},
"19": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"18": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"17": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"0x0008": {
"endpoint_attribute": "level",
"attributes": {},
"0x0300": {
"endpoint_attribute": "light_color",
"attributes": {},
"16": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"15": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"14": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"13": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"0x0008": {
"attributes": {},
"0x0300": {
"attributes": {},
"12": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"11": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"10": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"9": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"0x0008": {
"attributes": {},
"0x0300": {
"attributes": {},
"8": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"7": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"6": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"5": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0000": {
"attribute_name": "on_off"
"0x4001": {
"attribute_name": "on_time"
"0xfffe": {
"attribute_name": "attr_reporting_status"
"0x0012": {
"attributes": {},
"0x0008": {
"attributes": {},
"0x0300": {
"attributes": {},
"4": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"3": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0000": {
"0x0012": {
"attributes": {},
"2": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {},
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0000": {
"0x0012": {
"attributes": {},
"1": {
"device_type": {
"id": 6
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "modkam.ru"
"0x0005": {
"attribute_name": "model",
"value": "DIYRuZ_FreePad"
"out_clusters": {
"0x0006": {
"attributes": {},
"0x0012": {
"attributes": {},
"0x0008": {
"attributes": {},
"0x0300": {
"attributes": {},
anyone know why this happened ,place help me
