Hi all!
I am new to ESPHome and successfully implemented some test programs. My current test program is the following:
# Hardware:
# NRF52840 Board "SuperMini"
# 1x Reset button between pin "RST" and "GND"
# 2x buttons, 1x between pin "0.06" and GND and 1x between pin "0.08" and GND
# 1x external LED between pin "0.31" and GND
# 1x VEML7700 light sensor board: SDA to P1.00 and SCL to P0.11, 3V3 to VIN of the sensor
# 1x potentiometer between 3V3 and GND and wiper contact to P0.02
esphome:
# Red LED lights up briefly at boot
on_boot:
priority: -10
then:
- switch.turn_on: led1
- delay: 500ms
- switch.turn_off: led1
# Define the board
nrf52:
board: adafruit_itsybitsy_nrf52840
# Enable logger
logger:
# I2C configuration
i2c:
sda: P1.00
scl: P0.11
scan: true
# Enables the Zigbee stack
zigbee:
# Light sensor
- platform: veml7700
ambient_light:
accuracy_decimals: 2
update_interval: 10s
# ADC (potentiometer)
- platform: adc
pin: AIN0
name: "Poti Spannung"
unit_of_measurement: "V"
# Onboard LED (red)
switch:
- platform: gpio
pin: P0.15
# External LED
- platform: gpio
pin: P0.31
# Button configuration
binary_sensor:
- platform: gpio
pin:
number: P0.06
mode:
input: true
pullup: true
inverted: true
icon: "mdi:toggle-switch-off-outline"
# on_press:
# - switch.turn_on: led2
# on_release:
# - switch.turn_off: led2
- platform: gpio
pin:
number: P0.08
mode:
input: true
pullup: true
inverted: true
# on_press:
# - switch.turn_on: led1
# on_release:
# - switch.turn_off: led1
At the console output after flashing this program every thin works as expected: brightness, button and potentiometer values are reported as expected.
But I have the following issue:
The VEML7700 Lux sensor reports its value automatically and flawlessly to Home Assistant. However, the potentiometer (ADC voltage sensor) completely refuses to update on its own, even though the ESPHome console logs prove that the hardware, wiring, and code are processing the changes perfectly in real time. Only when updating the "AnalogInput" value "present_value" in the cluster setting manually via "Read attribute", the value is updated without problems.
Same for the pushbuttons -> no update on its on. Once it worked after multiple re-coupling, but overnight it failed again to update...
The sensor is connected using ZHA into Home Assistant. Of course I tried deleting the sensor (with zha.remove) and re-coupled it multiple times.
I don't know if this is a HomeAssistant or ESPHome issue, but the other sensors (non-DIY) are working flawlessly, therefore I posted my issue here.
I would be glad for any help!
