I have just finished setting up a few sensors in HomeAssistant.
I update the values quite a lot (every 30 seconds for now).
My HA is running on a Raspberry Pi 1 B running Raspbian.
When I click on a sensor, I get strange graphs where only some values seem to be displayed (see images).
Looking more closely, it seems that the value shown are the one received by HA when I was actively looking at the HA web interface.
Would anyone have ever seen this ? Or have any idea of the origin of this problem ?
I see it quite a lot, it usually means my sensor has gone off line resetting it usually resumes monitoring. Looks like yours were either not sending or HA was not receiving for 20hrs
If I restart both mysgw (MySensors gateway service) and home-assistant, it sometimes goes back to normal functionality (with the values from the restart plot correctly) and sometimes I only get one value and then it stops again.
The only thing that apparently allow me to get it completely fixed is to restart the Pi. I am trying to figure out how to stop and start the services, with what delay between them to fix it from a script…
Would there be a way to avoid having to restart both services almost every other day ?
Hello, same here… this is random - 1-4days…then i have to just restart PI and everything is working again - plotting from when i restarted PI. nothing is changed at sensors side… using MYSENSORS and other inputs aswell. also i;m using mysql…running hassbian with latest 0.45…
