Reposting this in the hope that someone can point me in the right direction!
I’ve been trying to get cast to nest to work, with no succes.
I have completed the google cast configuration and it shows the devices in the integration.
I’ve tried it initially as an action in an automation:
service: cast.show_lovelace_view
entity_id: media_player.nesthubfe8f
dashboard_path: dashboard-cast
And also tried using a blueprint:
alias: Cast to google hub
description: ""
use_blueprint:
path: kind3r/cast-and-re-cast-a-lovelace-view-to-a-google-hub.yaml
input:
player: media_player.nesthubfe8f
view: livingroom
I use nabu casa cloud and am on this version of home assistant:
- Core 2024.6.3
- Supervisor 2024.06.0
- Operating System 12.4
- Frontend 20240610.1
Log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/cast/home_assistant_cast.py:73
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 12:55:51 (3 occurrences)
Last logged: 13:24:08
[281472153765056] Error handling message: Unknown error (unknown_error) Anouk from 127.0.0.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36)
[281472074196752] Error handling message: Unknown error (unknown_error) Anouk from 127.0.0.1 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 793, in handle_execute_script
script_result = await script_obj.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1769, in async_run
return await asyncio.shield(create_eager_task(run.async_run()))
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 464, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 528, in _async_step
self._handle_exception(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 558, in _handle_exception
raise exception
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 763, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 726, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2741, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2784, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1080, in _async_admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/cast/home_assistant_cast.py", line 73, in handle_show_view
call.data[ATTR_VIEW_PATH],
KeyError: 'view_path'
