Hi, I am a bit stressed now as I’ve been trying to learn for several hours now, what suddenly went wrong with my home-assistant installation. It’s not loading the frontend any more.
I have look at the logger and I only get the following:
Blockquote 2018-01-29 00:41:57 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=316 from 2018-01-29 00:33:56.204800)
2018-01-29 00:42:26 WARNING (SyncWorker_0) [netdisco.ssdp] Error fetching description at http://192.168.0.254:49152/wps_device.xml
2018-01-29 00:42:28 WARNING (SyncWorker_0) [netdisco.ssdp] Found malformed XML at http://192.168.0.87:9080: status=ok
2018-01-29 00:42:39 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/local/lib/python3.6/asyncio/tasks.py”, line 180, in _step
result = coro.send(None)
File “/usr/src/app/homeassistant/helpers/entity_component.py”, line 399, in async_process_entity
new_entity, self, update_before_add=update_before_add
File “/usr/src/app/homeassistant/helpers/entity_component.py”, line 247, in async_add_entity
yield from entity.async_update_ha_state()
File “/usr/src/app/homeassistant/helpers/entity.py”, line 217, in async_update_ha_state
attr = self.state_attributes or {}
File “/usr/src/app/homeassistant/components/media_player/init.py”, line 875, in state_attributes
in ATTR_TO_PROPERTY if getattr(self, attr) is not None
File “/usr/src/app/homeassistant/components/media_player/sonos.py”, line 988, in source_list
return self._coordinator.source_list
File “/usr/src/app/homeassistant/components/media_player/sonos.py”, line 990, in source_list
model_name = self._speaker_info[‘model_name’]
TypeError: ‘NoneType’ object is not subscriptable
2018-01-29 00:42:43 WARNING (SyncWorker_4) [homeassistant.components.zwave] zwave not ready after 30 seconds, continuing anyway
2018-01-29 00:42:45 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
I cannot see anything critical there. Can someone help me??Thanks!
