I started all over with my hassio. i did a fresh install. but now I can’t seem to get it to come up. I don’t even see it in my list of connected devices. any ideas on what I can do to connect to my device?
I’m using a mac, raspberry pi 3 B, wifi setup. Tried ethernet setup as well. My device never shows up.
plug a monitor and keyboard into it. then troubleshoot.
boots up fine to HassOS> . Im guessing some sort of command line. I’m lost now.
@qlectric Start fresh, try this and see how you go.
https://drive.google.com/open?id=1oKhnQ1rz-Yd5HheA8rNk5YNq8e67-5Kh
With me using a Mac, what would be the best option?
What does using a Mac have to do with it?
LOL if I really knew the answer to that I probably wouldn’t have asked in the first place. Ok so nothing. Thanks
This partly worked. I have had some issues. This below happens right after the “software-properties-common”
'> Get:1 Index of /raspbian buster/main armhf gir1.2-packagekitglib-1.0 armhf 1.1.12-5 [35.9 kB]
Err:1 Index of /raspbian buster/main armhf gir1.2-packagekitglib-1.0 armhf 1.1.12-5
File has unexpected size (8096 != 35892). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
Hashes of expected file:
- SHA256:eb064bc5c349a96c567bded9abb4457ff74e5eb9e4f89c6242124bf04aea31d1
- SHA1:d266bd1547f7d7e995ef34dc3bccc20d7a6ace91 [weak]
- MD5Sum:7bd228e2bd06354d8ea52ee38e2b953a [weak]
- Filesize:35892 [weak]
Get:2 Index of /raspbian buster/main armhf python3-distro-info all 0.21 [7,896 B]
Err:2 Index of /raspbian buster/main armhf python3-distro-info all 0.21
File has unexpected size (8096 != 7896). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
Hashes of expected file:- SHA256:0c2d0ddf04cca3f7a994b84ea79712db65657cfd5a607e8f69339830e9925f0a
- SHA1:5ad73589ce04dc8713a1ac70578eb1a8405cc95a [weak]
- MD5Sum:c093737d08fff6e5f28efcd80cc904fa [weak]
- Filesize:7896 [weak]
Get:3 Index of /raspbian buster/main armhf python3-pycurl armhf 7.43.0.2-0.1 [62.8 kB]
Err:3 Index of /raspbian buster/main armhf python3-pycurl armhf 7.43.0.2-0.1
File has unexpected size (8096 != 62760). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
Hashes of expected file:- SHA256:7496a4d97ed833e7928ea0b19891deee49b1b873a9d67cae29aba7c56fcefafc
- SHA1:86aca613bafb980745cce69c959779722483e258 [weak]
- MD5Sum:1139eaa31fa650f0bf32fdb47ec4c4d2 [weak]
- Filesize:62760 [weak]
Get:4 Index of /raspbian buster/main armhf python3-software-properties all 0.96.20.2-2 [49.6 kB]
Err:4 Index of /raspbian buster/main armhf python3-software-properties all 0.96.20.2-2
File has unexpected size (8096 != 49628). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
Hashes of expected file:- SHA256:2c79865843dfe61531df5f947ee4eaded74843112b3bc1c3a65138970cfd4d3b
- SHA1:7ec8970572e4bb08fb366f27c4332d5f0898af1c [weak]
- MD5Sum:9e8be0af7798b2a714127870fc1c92b0 [weak]
- Filesize:49628 [weak]
Get:5 Index of /raspbian buster/main armhf software-properties-common all 0.96.20.2-2 [83.3 kB]
Err:5 Index of /raspbian buster/main armhf software-properties-common all 0.96.20.2-2
File has unexpected size (8096 != 83328). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
Hashes of expected file:- SHA256:0b939d01144489cbbeb1efb9b7f9aeb7f35fdc5e1a17e0dbc0d1ed175419c4ee
- SHA1:645d19fc0e93a833379faf0f11d941e564355f75 [weak]
- MD5Sum:f42d90059489f6ff778f33b7b7db47c6 [weak]
- Filesize:83328 [weak]
Get:6 Index of /raspbian buster/main armhf unattended-upgrades all 1.11.2 [79.0 kB]
Err:6 Index of /raspbian buster/main armhf unattended-upgrades all 1.11.2
File has unexpected size (8096 != 79000). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
Hashes of expected file:- SHA256:926edbaaf5c745b413ef5da5ba28c9352b01770befcecc556ecf795cbd6cc8f6
- SHA1:f35810e0e12d54014660fb82b68b2a13e841dbc4 [weak]
- MD5Sum:92c8d8cecece9312e23a51ad37f6b738 [weak]
- Filesize:79000 [weak]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/packagekit/gir1.2-packagekitglib-1.0_1.1.12-5_armhf.deb File has unexpected size (8096 != 35892). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/d/distro-info/python3-distro-info_0.21_all.deb File has unexpected size (8096 != 7896). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/p/pycurl/python3-pycurl_7.43.0.2-0.1_armhf.deb File has unexpected size (8096 != 62760). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/software-properties/python3-software-properties_0.96.20.2-2_all.deb File has unexpected size (8096 != 49628). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/software-properties/software-properties-common_0.96.20.2-2_all.deb File has unexpected size (8096 != 83328). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/u/unattended-upgrades/unattended-upgrades_1.11.2_all.deb File has unexpected size (8096 != 79000). Mirror sync in progress? [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Unable to fetch some archives, maybe run apt-get update or try with > --fix-missing?’
Any ideas on what’s going on?
run sudo apt-get update --fix-missing
, then install the dependencies list again.
still having issues…the device is unresponsive now. I’m going to format and start all over.
