I’m starting to experience this a lot too. Currently on 0.36.1. If I am doing a lot of HA restarts, because of config changes, eventually it just stops working and throws this error, and I have to reboot. Something is not getting closed properly when the service is shut down, I’m guessing.
I haven’t got it since I rebooted back in Nov. but I haven’t don’t much configurations since then.
I still have the same problem, too (0.37.0). I imagine it could home something to do with the webinterface, I have tons of connections to :8123, even is hass is killed - and even in established state.
I’m still seeing the exact same thing
+1
Observed about 20-30 web connections.
My server just died today, stopped responding to all commands. When I went to check the log file, it was this issue again.
I’m not sure what to do to troubleshoot, but would be happy to help if someone can give me some direction.
Possible solution:
I ran lsof | grep 8123
and found that there were tons and tons of these sort of lines:
node 401 ob1 18u IPv4 0xdd2a305bd36460cf 0t0 TCP localhost:62801->localhost:8123 (ESTABLISHED)
node 401 ob1 19u IPv4 0xdd2a305bccf36cef 0t0 TCP localhost:62802->localhost:8123 (ESTABLISHED)
node 401 ob1 20u IPv4 0xdd2a305bccf37edf 0t0 TCP localhost:62803->localhost:8123 (ESTABLISHED)
node 401 ob1 21u IPv4 0xdd2a305bccf35aff 0t0 TCP localhost:62804->localhost:8123 (ESTABLISHED)
The only thing that was running node was homebridge. I killed and restarted homebridge and tada homeassistant was working again! Not sure why it was happening in the first place though. But it seems to be related at least in some regard to quitting and restarting hass with the connections not having a chance to close.
edited to reflect homeBRIDGE not homeBREW… oops!
I have found this related to homebridge.
If i stop homebridge. Restart HA and then start homebridge everything plays nice.
In my setup it looks like homebridge goes on a frenzy and opens 100’s of connections to the HA API.
My original setup was on a Mac Mini. Gave up on that a couple of weeks ago and built loaded Hassbian on a Pi 3. No errors and install was easier. Backup of the SD card is easy so if something goes wrong I can quickly fall back to a working system.
Experienced the same thing here last night running OS X Sierra and HASS 0.39.2. Not running homebridge and no zombie node processes running.
Hope this doesn’t become a re-occurring thing.
I’m egetting the same. Homeassistant 0.40 no home bridge.
Any ideas on how to increase the number of files? Raspbian?
Couldn’t get to work with MySQL reliably. Switched to Postgres. Now getting the following after 3-4 days. Anybody know how to fix this one? Guess the same reason my nmap scan is also failing
requests.exceptions.ConnectionError: HTTPConnectionPool(host='xxx', port=8086): Max retries exceeded with url: /write?db=home_assistant (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x3c5f66b0>: Failed to establish a new connection: [Errno 24] Too many open files',))
Rnin lsof see a lot of entries like this
hass 720 1061 homeassistant 55u 0000 0,11 0 4714 anon_inode
hass 720 1061 homeassistant 56u 0000 0,11 0 4714 anon_inode
hass 720 1061 homeassistant 57u unix 0xb68eaa00 0t0 28682 socket
hass 720 1061 homeassistant 58u unix 0xb68ea100 0t0 28683 socket
hass 720 1061 homeassistant 59u 0000 0,11 0 4714 anon_inode
hass 720 1061 homeassistant 60u unix 0xb6964300 0t0 23403 socket
hass 720 1061 homeassistant 61u unix 0xb9358300 0t0 33076 socket
hass 720 1061 homeassistant 62u unix 0xb935a700 0t0 33077 socket
hass 720 1061 homeassistant 63u 0000 0,11 0 4714 anon_inode
hass 720 1061 homeassistant 64u unix 0xb6965200 0t0 32212 socket
hass 720 1061 homeassistant 65u unix 0xb6964600 0t0 32213 socket
hass 720 1061 homeassistant 66u 0000 0,11 0 4714 anon_inode
hass 720 1061 homeassistant 67u 0000 0,11 0 4714 anon_inode
hass 720 1061 homeassistant 68u 0000 0,11 0 4714 anon_inode
hass 720 1061 homeassistant 69u unix 0xb935a100 0t0 48704 socket
hass 720 1061 homeassistant 70u unix 0xb935b000 0t0 48705 socket
This used to happen to me after restarting HA too many times after a reboot. I would have to reboot to fix it.
Now, since 0.40, it happens after HA is running for a while. It’s completely broken my setup. It appears macOS just has an insanely low limit for this. We just need to increase the allowed number of files to be open.
You can see the list here:
$ ulimit -a
-t: cpu time (seconds) unlimited
-f: file size (blocks) unlimited
-d: data seg size (kbytes) unlimited
-s: stack size (kbytes) 8192
-c: core file size (blocks) 0
-v: address space (kbytes) unlimited
-l: locked-in-memory size (kbytes) unlimited
-u: processes 709
-n: file descriptors 256
after running:
ulimit -Sn 10000
it shows
-u: processes 709
-n: file descriptors 10000
But it doesn’t stick on a reboot. It goes back to 256.
Does anyone know the best practice for getting this to stick?
Has anyone found a solution to this?
I’m finding HA has become totally unusable in the last few weeks due to this problem.
This post found that Web OS TV was leaking files, so if you have that it might be worth turning off
Had it, commented it out, still having issues.
How about these two
Exactly the same behavior today. Restart HA and Homebridge and everything fine. Perhaps it is something with the latest homebridge version?
A post was split to a new topic: Not enough system resources / too many files open with 0.69.0 upgrade
