Hi Everyone,
I’m not to sure where to go so I have decided to post here instead. I’m running the latest HA with DuckDNS/Lets Encrypt installed, now when I install either Adguard or Pi-Hole, either two addons work and have no issues, but when it’s running it stops me from being able to receive notifications to my device using the notify call. I have attached the error that I get in my error logs when I try and send myself a notification using HA, hoping someone can help me be able to receive these notifications as well as having one of these adblockers working for me:
EDIT:
It seems as though when I have either adblocker running it stops my AirCast addon also, I think.
2019-02-19 20:20:09 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1902232912] Error handling message: {'type': 'call_service', 'domain': 'notify', 'service': 'ios_todds_iphone', 'service_data': {'message': 'test'}, 'id': 25}
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6f289130>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f289130>: Failed to establish a new connection: [Errno -3] Try again',))
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/websocket_api/decorators.py", line 17, in _handle_async_response
await func(hass, connection, msg)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/websocket_api/commands.py", line 148, in handle_call_service
connection.context(msg))
File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1130, in async_call
self._execute_service(handler, service_call))
File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1152, in _execute_service
await handler.func(service_call)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 117, in async_notify_message
await notify_service.async_send_message(**kwargs)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/notify/ios.py", line 94, in send_message
req = requests.post(PUSH_URL, json=data, timeout=10)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6f289130>: Failed to establish a new connection: [Errno -3] Try again',))
