Hi everyone,
I’m a bit desperate as I’ve tried to install hassio following the “standard” procedure on a brand new Raspberry Pi 4 a few times now for 3 days and always get the same error saying there’s no more space (on my 64Gb sd card). Note that I was able to make it work a few days ago with a 16Gb card, but the card was “burnt” by the raspberry…
I flashed several times the card with SD card formatter, took the latest 64 bit version from the website that I loaded onto the sd through Etcher (and also tried Win32DiskManager). I also tried with the 32 bit version, exact same happens.
- I start the ethernet-connected raspberry : green light show something is happening, BUT it doesn’t appear on my local network (even after more then 30 minutes).
- I unplugg / replug, and after a few minutes, the raspberry appear on the local network, and when I check on my browser, I arrive on the “preparing home assistant” page BUT… I see the error saying that’s it a 404 and there’s no space available:
Updateing image homeassistant/raspberrypi4-homeassistant:landingpage to homeassistant/raspberrypi4-homeassistant:0.116.4
Downloading docker image homeassistant/raspberrypi4-homeassistant with tag 0.116.4.
Can't install homeassistant/raspberrypi4-homeassistant:0.116.4 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi4-homeassistant:0.116.4: No such image: homeassistant/raspberrypi4-homeassistant:0.116.4").
This error is often caused by not having enough disk space available. Available space in /data is: 0.2 GiB
Here the full log.
Any ideas here ?
Thanks in advance !
