Not JSON RESTful Sensor?
Are a few days that I discovered HASS, and suddenly I was falled in love!
So… now I would like to gather data from my Blynk server via RESTful API.
The problem is that my Blynk server answer with a simple unformatted (not JSON) string like
["17.300"]
for a float value.
My configuration,yaml is
  - platform: rest
    resource: https://192.168.1.189:9443/2affa38aa6f245d39dff7ff0ff2ec4c7/pin/V8
    verify_ssl: false
    value_template: '{{ value }}'
    unit_of_measurement: °C
The HASS display the entiere string that my server return… how I can elimiate the brackets and the quotes to display a true float number?
@Fulvi_Igor,
try '{{ value[0] }}' since its a list. And can use the float filter | float to ensure its a number.
Regards
… using
value_template: '{{ value[0] | float }}'
… I got:
0.0°C
… and using
value_template: '{{ value[0] }}'
… I got:
… unespected result!
@Fulvi_Igor, can you post the entire feedback from the sensor you have?
Regards
Typing:
curl -k -X GET https://192.168.1.189:9443/2affa38aa6f245d39dff7ff0ff2ec4c7/pin/V8
answer is:
["17.200"]
@Fulvi_Igor, Well one crude way I think to solve it, will be to turn it into a string first.
I will try ""join(value), this will output a string, which you can then turn into a float. I am no expert, but I think this should work.
Regards
It’s not pretty, but try {{ value | replace('"','') | replace("[","") | replace("]","") | float }}.
Using your “formula” in the Developer Tools - Templates it works, but using the same string in the configuration.yaml it return me a error! :sweat:
This is my code:
  - platform: rest
    verify_ssl: false
    value_template: '{{ value | replace('"','') | replace("[","") | replace("]","") | float }}'
And this is the error I get:
ERROR (SyncWorker_0) [homeassistant.util.yaml] while parsing a block mapping
  in "/config/configuration.yaml", line 105, column 5
expected <block end>, but found '<scalar>'
The problem is the template has single and double quotes already. Try it like this:
- platform: rest
    verify_ssl: false
    value_template: >-
@NotoriousBDG YESSSA! it works! the “>-” solve the problem! really many thanks!
