Not possible conect mqtt "eclipse-mosqutto", in ihost sonoff "conteiners"
Until October last year MQTT was working fine for me on IHOST SONOFF, but it was updated and stopped working.
I was using the following configuration:
Configure or eclipse-mosquitto
Bridge mode
Port 1889 - 1883
Volume:
mosquittoConfig – /mosquitto/config
mosquittoConfig – /mosquitto/data
mosquittoConfig – /mosquitto/log
mosquitto.yml
listener 1883
allow_anonymous true
If you have any suggestions on how to configure MQTT, please let me know.
log
Config loaded from /mosquitto/config/mosquitto.conf
Opening ipv4 listen socket on port 1883
Opening ipv6 listen socket on port 1883
mosquitto version 2.0.2.20 running
Client disconnected due to protocol error
New connection from xxx.xxx.xxx.xxxx:xxxx on port 1883
this page says ihost doesnt support mqtt and you should use API
If it was working before update its likely they made a change.
Tried installing para-ewelink, however it also cannot find the available port, any additional ideas, thanks
