Thanks very much. I have also tried without this attribute:
- platform: rest
resource: https://admiraltyapi.azure-api.net/uktidalapi/api/V1/Stations/0124/TidalEvents?duration=7
headers:
Authorization: !secret api_key_admiralty
value_template: '1' # dummy value, not used; avoids the "State max length is 255 characters" error
json_attributes_path: '$..[?(@.EventType=="HighWater")]'
json_attributes:
- DateTime
- Height
but also got that same error.
The resource output is small enough to fit it in the post (though also in pastebin if that’s easier):
"Date": "2021-01-06T00:00:00",
"DateTime": "2021-01-06T04:38:39.3",
"EventType": "HighWater",
"Filtered": false,
"Height": 4.5645572811437045,
"IsApproximateHeight": false,
"IsApproximateTime": false
"DateTime": "2021-01-06T10:57:45",
"EventType": "LowWater",
"Filtered": false,
"Height": 0.6164370982704671,
"DateTime": "2021-01-06T17:11:43.217",
"Filtered": false,
"Height": 4.530521927172035,
"DateTime": "2021-01-06T23:05:37.5",
"Filtered": false,
"Height": 1.2180845949919092,
"Date": "2021-01-07T00:00:00",
"DateTime": "2021-01-07T05:31:33.333",
"Filtered": false,
"Height": 4.4727851870133435,
"DateTime": "2021-01-07T12:05:07.5",
"Filtered": false,
"Height": 0.6464246556611379,
"DateTime": "2021-01-07T18:11:13.333",
"Filtered": false,
"Height": 4.387457911198173,
"Date": "2021-01-08T00:00:00",
"DateTime": "2021-01-08T00:20:52.5",
"Filtered": false,
"Height": 1.2424560539342702,
"DateTime": "2021-01-08T06:38:13.333",
"Filtered": false,
"Height": 4.405241312964828,
"DateTime": "2021-01-08T13:19:22.5",
"Filtered": false,
"Height": 0.6664784228584787,
"DateTime": "2021-01-08T19:26:46.667",
"Filtered": false,
"Height": 4.328524879681343,
"Date": "2021-01-09T00:00:00",
"DateTime": "2021-01-09T01:43:00",
"Filtered": false,
"Height": 1.1919323398634305,
"DateTime": "2021-01-09T07:56:20",
"Filtered": false,
"Height": 4.436229325981978,
"DateTime": "2021-01-09T14:31:22.5",
"Filtered": false,
"Height": 0.6893275961729552,
"DateTime": "2021-01-09T20:42:46.667",
"Filtered": false,
"Height": 4.395592077530186,
"Date": "2021-01-10T00:00:00",
"DateTime": "2021-01-10T03:01:45",
"Filtered": false,
"Height": 1.077913796529528,
"DateTime": "2021-01-10T09:11:16.667",
"Filtered": false,
"Height": 4.605305470483266,
"DateTime": "2021-01-10T15:42:15",
"Filtered": false,
"Height": 0.7196127145963841,
"DateTime": "2021-01-10T21:52:26.667",
"Filtered": false,
"Height": 4.562212089460421,
"Date": "2021-01-11T00:00:00",
"DateTime": "2021-01-11T04:16:00",
"Filtered": false,
"Height": 0.9198850012712186,
"DateTime": "2021-01-11T10:15:40",
"Filtered": false,
"Height": 4.84784122695461,
"DateTime": "2021-01-11T16:49:45",
"Filtered": false,
"Height": 0.7449087740503451,
"DateTime": "2021-01-11T22:53:40",
"Filtered": false,
"Height": 4.756685518327773,
"Date": "2021-01-12T00:00:00",
"DateTime": "2021-01-12T05:25:45",
"Filtered": false,
"Height": 0.7416727994898556,
"DateTime": "2021-01-12T11:13:43.333",
"Filtered": false,
"Height": 5.0724574536621,
"DateTime": "2021-01-12T17:52:45",
"Filtered": false,
"Height": 0.7645267756405048,
"DateTime": "2021-01-12T23:47:30",
"Filtered": false,
"Height": 4.921005217884829,
My end goal is to get a list of upcoming high tides with time & height, so I need all the “DateTime”, and “Height” entries where “EventType” is “HighWater”, in a form where I can then display them in some sort of table layout.
I’d already got this working and displaying perfectly using an alternative tides source of https://api.stormglass.io, so it’s probably easiest to explain my goal by showing what I already had working. The stormglass provider gives me json like this:
"data": [
"height": 0.6845618910459339,
"time": "2021-01-06T12:18:00+00:00",
"type": "low"
"height": 4.426741654879187,
"time": "2021-01-06T18:02:00+00:00",
"type": "high"
"height": 1.3619747293854356,
"time": "2021-01-07T00:44:00+00:00",
"type": "low"
… so I’d been able to read it all into a “data” attribute like this:
- platform: rest
resource: https://api.stormglass.io/v2/tide/extremes/point?lat=51.778160&lng=0.928929&datum=MLLW
headers:
Authorization: !secret api_key_stormglass
json_attributes:
- 'data'
Which looked like this:
I then used used a markdown sensor with lots of template commands to extract the high tide info and format it in a simple table, to give me the output exactly as I wanted:
Unfortunately I then realised this was inaccurate, as the provider didn’t have a “station” that was close enough to the location I was interested in. My new “admiralty” provider has lots more stations and one in the exact location I need.
I’m probably suffering from being very unfamiliar with json in general - this is my first time using it. I think the problem is that the above “stormglass” api I got working is providing a top level dictionary (“data” : [) , so I can just reference that “data” to pull out, whereas this new admiralty api is just a load of list elements and I have nothing to reference…
