not sure if your expectation is correct. Firing the Netatmo event is not triggering a webhook call.
The netatmo systems should call your HA Url and when recieved, the netatmo event will happen with content.
So testing webhook, is not possible inside HA environment. You’ll need to wait for the external call (or maybe someone know how to send a test from a web dev account on netatmo)
Thanks for clarifying. This is exactly my understanding, the point is that I’m not receiving any.
For instance, my indoor station (temperature, humidity etc) is not sending any webhook.
I have too the weather station, there is no need for webooks as its polling from cloud.
You can also read in the documentation that this device is excluded from webhook implementation.
